Old 13-06-2011, 11:11 PM   #1 (permalink)
Smile DVD drive doesn't reads!!!
SONY optiarc AD-7220A - the drive shows power and is identified by the system and takes in the disk but doesn't read it after few blinks of light.
system runs- Win xp sp2pro, intel pentiun 4 2.66ghz, 512 mb ram.
ANKIT7540 is offline   Reply With Quote
Old 13-06-2011, 11:57 PM   #2 (permalink)
Default Re: DVD drive doesn't reads!!!
Clean the read laser.
Faun is online now   Reply With Quote
Old 14-06-2011, 12:33 AM   #3 (permalink)
Technoholik !!
Tech&ME's Avatar
This is very common in IDE optical drives.
1. Purchase a cleaning CD and try to clean it using it. (some music will play)
2. If this doesn't work then go to sony website and get latest firmware for the Drive and update as per instruction.
(there is a guide regarding this issue in the hardware tutorial section of this forum)
[Desktop]
[Laptop]
Tech&ME is online now   Reply With Quote
Old 14-06-2011, 04:26 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
Common problem.
As suggested get a cleaning kit, and clean your drive.
But don't spend behind repairing it, its not worth it, as you can get a new one for around 900 bucks.
Blogging at:
Technostarry
saqib_khan is offline   Reply With Quote
- by c4u
