Old 11-06-2011, 03:38 PM   #1 (permalink)
Unhappy SMPS Burns!!!!
Hi,
I bought a PC two weeks back.
Intel i3
Asus motherboard p7h55-m
SMPS -Zebronics 450w
ASUS 20" HD+
I was using a V-guard UPS which was having some sort of problem as there was some compatibility problem with the inverter installed in my house.The UPS restarted when the power supply resumed in the mains. somehow I managed to turn off the pc soon after the power goes.
I used the same UPS with the new PC and 2 days after buying the PC there was a power failure and before I could turn Off the PC the power resumed and UPS got restarted.I could see some flash at the back of the CPU and the smps was burnt.
I replaced the smps and after one day the bios crashed and the I could'nt start the pc or enter bios.Then I replaced the Motherboard also.
Toady there was apower failure and all of a sudden there was a lot of noise from the UPS and CPU got turned off. When I restarted the UPS I could again see the flashes and the smps got burnt again
When I called the dealer he told me to check the power supply and inverter in my house before he can replace the SMPS.
Now I am using My old P4 System with Zebronics SMPS itself and it's working Fine,other than the Problem with the UPS.It's 6 years Old
What should I do..Please Help.
dhaneshka is offline   Reply With Quote
Old 11-06-2011, 08:20 PM   #2 (permalink)
Mmmph!!!
doomgiver's Avatar
Default Re: SMPS Burns!!!!
carefully take out the smps and throw it down from the highest building you can find
then take a cricket bat and smash it until its totally broken into pieces
then get a good smps like fsp saga II 350W
if you had got a good smps in the first place, you would have saved a lot of money
mods please sticky this in the "SEE, I TOLD YOU SO" section
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
Old 11-06-2011, 08:42 PM   #3 (permalink)
R2K
In the Zone
R2K's Avatar
Its clear that UPS is f**ked up...get rid of it....Or else you would have to get a replacement SMPS on every power failure and thats gonna piss off your PC dealer soon
Acer Aspire 4930G laptop- Core 2 Duo T5800 3GB ram, 320GB+LG XG1(2TB),nVIDIA 9300GS 256MB,FingerPrint Scanner,HDMI, 802.11a/b/g/Draft N Wifi
Sony Ericsson Xperia Arc S (Gloss Black)
R2K is online now   Reply With Quote
Old 11-06-2011, 09:39 PM   #4 (permalink)
Sin
^ +1.
V-Guard UPS sucks. I had used them a long time ago and i had 2 get 3 replacements + repairs b4 I finally switched to APC.
DUMP ur V-Guard UPS.
»~$in~«
sinoop_joy is offline   Reply With Quote
Old 11-06-2011, 09:53 PM   #5 (permalink)
Dust in the Wind
Skud's Avatar
@ doomgiver: the SMPS is working properly with another p4 system. Apparently the 6-year old UPS has given up.
@OP: get it replaced as early as possible. Get a APC 600VA. If its not available then a Microtek will do fine.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 11-06-2011, 10:33 PM   #6 (permalink)
The Sorcerer's Avatar
Power requirements and performance cannot be compared with an i3. Move on, get a decent power supply at the same time.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 11-06-2011, 10:55 PM   #7 (permalink)
Dust in the Wind
Skud's Avatar
But is not i3 more power efficient than P4?
Gaming Rig:
HTPC Rig:
Old 11-06-2011, 11:07 PM   #8 (permalink)
The UPS is Not that old..It's only 6 months old... Anyway I will have to try something else that works with my inverter..
Please suggest me some good smps
The 6 year old one is also having zebronics SMPS and is still working perfectly..
Old 11-06-2011, 11:10 PM   #9 (permalink)
Dust in the Wind
Skud's Avatar
Oops sorry. I goof up UPS with the P4 system. Please tell your budget for the SMPS. But if the problem lies elsewhere your newer SMPS can also go kaput. So first check if everything else is alright.
Gaming Rig:
HTPC Rig:
Old 12-06-2011, 08:22 AM   #10 (permalink)
Efficiency of a processor is irrelevant with clean power flow. processor isn't the only component taking power.
Said it before, will say it again. More advanced anything goes, more sensitive it becomes towards bad power supply. Efficiency got nothing to do with clean power supply. Rest of the explanation is on that psu guide. There's no point for me to repeat what's already been pointed out.
Just take this opportunity to do justice to your system and upgrade to a decent power supply.
Hardware BBQ
Old 12-06-2011, 11:20 AM   #11 (permalink)
Game on !!!
anupam_pb's Avatar
A P4 uses 1.2 V @ standby whereas i3 uses 0.95V @ standby.
Checked these using GPUZ
I'v used CPUZ not GPUZ
My PC config : Intel core i3 2.93 Ghz, 2 x 2GB DDR3 1333Mhz, Intel DH55TC, XFX Radeon 5670 1 GB GDDR5, Windows 7 Ultimate 64-bit, LG DVD writer, Corsair CX430W, SAMSUNG 17" LCD (4:3); Samsung Galaxy Y
anupam_pb is offline   Reply With Quote
Old 12-06-2011, 11:48 AM   #12 (permalink)
Super Moderator
asingh's Avatar
So...what you trying to say by this.
asingh is online now   Reply With Quote
Old 12-06-2011, 12:06 PM   #13 (permalink)
saswat23's Avatar
Same here. I dont get you.
BTW are you sure that you are running your i3 rig with 5670, all on a 160W PSU..
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 12-06-2011, 12:10 PM   #14 (permalink)
Even last week a couple of guys posted in various threads they used a system all on a PSU of kust 160w(seems like a joke to me )
Well its normal, i3 are supposed to be more efficient than a x86
thetechfreak is online now   Reply With Quote
Old 12-06-2011, 12:13 PM   #15 (permalink)
saswat23's Avatar
Thanks, but any links..
Old 12-06-2011, 12:17 PM   #16 (permalink)
Here you go Saswat-
http://www.thinkdigit.com/forum/grap...ml#post1413348
Old 16-06-2011, 05:43 PM   #17 (permalink)
Where's my M4A1
change ur UPS to APC as well as change ur PSU to FSP SAGA 500W
Keep the faith, not here to win trophies, not here to win the league, only here to show people how we play.... ARSENAL!!!!!!!!!!!!!!!
1993gregory is offline   Reply With Quote
- by c4u
