I'm posting this on behalf of my uncle..
The problem is, the system doesnt turn on most of the times. Instead only a single green led glows on the motherboard.
* When i tried replugging all the connections, it worked worked (got switched on) for 2-3 times and failed to turn on..
*If i try starting it after 2hrs by leaving it idle till then without any power supply, it again works for another 2-3 times..
*Every morning on the first attempt, it works, but it only lasts for 2-3 start ups..
*** I even checked by removing the power switch's connection on the motherboard and shorted in manually, still no use..
pc config:
core2duo, intel mobo, 500+160 SATA hdd, 2gig ddr3, 450w psu (prime source technology).
Where could be the problem guys..?
the system is less than a year old and is still under warranty. .
