Old 09-06-2011, 12:31 AM   #1 (permalink)
Unhappy RAM problem
Yesterday iadded a ddr2 2gb ram to my existing config of
Pentium 4 3.2 ghz processor
2gb ddr 2 ram
Nvidia 9500 GT Graphic
den after i insert it in da ram slot and open da comp da comp starts giving beeping sounds and when i remove it it works fine
Any help on how can i use it???
darealBIB is offline   Reply With Quote
Old 09-06-2011, 10:33 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: RAM problem
Q:Is the RAM is used one or brand new?
r u inserting the RAM properly?
Old 09-06-2011, 12:42 PM   #3 (permalink)
its a used 1 i used it till 6 months ago and i took it out god knows why
ya i inserted it correctly
Old 09-06-2011, 02:26 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
clean the RAM & slots properly to remove dusts.
even after cleaning & removing dusts the RAM doesn't work then
RAM memory banks is corrupted
Old 09-06-2011, 02:35 PM   #5 (permalink)
abhidev's Avatar
try to clean the ram with with an eraser.......and then insert it again...
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is online now   Reply With Quote
Old 09-06-2011, 02:43 PM   #6 (permalink)
saswat23's Avatar
may be the RAM or the slot is kaput.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
- by c4u
