Old 04-06-2011, 08:26 PM   #1 (permalink)
mohit sharma's Avatar
Default Trouble in deciding external HDD
Hello guys,
I am planning to buy an external HDD, but i am getting it hard to decide which one, i prefer 1TB HD but can go for 500GB, because what matters most is the data i will store in it.
i was going for 1TB goflex from seagate, but people suggested me about it's complaints of freequent crashing, please suggest me:
1) if i should go for 1TB or 500 GB, which one is more reliable,
2) which brand and which model should i trust most for reliability?
Thanks in advance.
" :arrow: CONNECTION BETWEEN LIFE AND TECHNOLOGY " is my topic of research !!!!
don't believe and respect any authority with closed eyes other then almighty !!!!! :idea:
mohit sharma is offline   Reply With Quote
Old 05-06-2011, 05:15 PM   #2 (permalink)
Default Re: Trouble in deciding external HDD
me2 thinking of getting a Seagate GoFlex 500Gb from Flipkart (or locally). what other alternate to consider?
Capacity: 500Gb max.
Budget: ~2.7k
Usage: day to day use. E-Sata cable/connectivity if possible within budget.
PS: not want to make a 2nd thread as OP & i have same requirement
Sam is offline   Reply With Quote
Old 06-06-2011, 09:43 AM   #3 (permalink)
mohityadavx's Avatar
Budget: ~2.7k
Sam go 4 it!!!
People will sugget u to go 4 Wd but WD give only 3 year warranty as compared to 5 year seagate warranty.
@ OP : I am using seagate goflex 1TB since a year no problem tilll now.
XPS 15 | Infibeam Pi |LG P500 |GoGear SA52XX | Sony PS2 | Sony H55 | Sennheiser CX 180 , MX760
For Free Legal Documentation - Rent Agreement/RTI etc
KAGZAAT
www.bleedlaw.com For Law student & aspirant
mohityadavx is offline   Reply With Quote
Old 06-06-2011, 09:48 AM   #4 (permalink)
without any second thought go for 500 gb seagate goflex
Ali Stone is offline   Reply With Quote
Old 06-06-2011, 11:25 AM   #5 (permalink)
What The.... !!!
funkysourav's Avatar
how much would the 1tb and 500gb goflex cost?
funkysourav is offline   Reply With Quote
Old 06-06-2011, 11:31 AM   #6 (permalink)
Originally Posted by mohityadavx View Post
Sam go 4 it!!!
Seagate website said it carries 5yr warranty. SMC have the Go (not GoFlex) & is listed as 2yr warranty. i mailed them about the warranty period but no reply. even ITWares & Flipkart list 3yr warranty. thinking of going for GoFlex but if someone can clear doubt about this warranty. most probably will buy it by end of this month.
i think i'll need to talk directly to seagate.
2650-2750 everywhere for the 500Gb. so if i buy locally it'll cost around 2800.
Old 06-06-2011, 12:03 PM   #7 (permalink)
Manc
xtremevicky's Avatar
Go for Sea gate . How much can you spend ?
You can buy from letsbuy.
If you like the Post , There is a Rep Button ,
If not then Understand that, There are people with different Opinions !
xtremevicky is offline   Reply With Quote
Old 06-06-2011, 04:04 PM   #8 (permalink)
^^ was it for me or op?
BTW, confirmed by Sorcerer, warranty on goflex is 3yrs, not 5. will get.it once exam is over.
Old 11-06-2011, 07:16 PM   #9 (permalink)
Exclamation Re: Trouble in deciding external HDD
Queries:
1)Any problem with 1TB Goflex in terms of performance?
2) does 1TB goflex requires external power ?
3) which one is more dependable 500GB goflex or 1TB GoFlex ?
4) i don't have budget probs till 1TB, which one should i opt for WD or Seagate Goflex ?
- by c4u
