Old 01-06-2011, 02:53 PM   #1 (permalink)
Game on !!!
anupam_pb's Avatar
Default Is it RAM issue ?
I've a BSNL broadband connection with dial up. Sometimes while connecting to the internet(using dial up), my PC hangs up badly. It starts responding after 5 min, that also not completely. Dial up dialog box is in not responding & i've to restart my PC(not by using reset button).
What could the problem be ? Is it due to windows 7 64bit running in 2GB RAM ?
My PC config : Intel core i3 2.93 Ghz, 2 x 2GB DDR3 1333Mhz, Intel DH55TC, XFX Radeon 5670 1 GB GDDR5, Windows 7 Ultimate 64-bit, LG DVD writer, Corsair CX430W, SAMSUNG 17" LCD (4:3); Samsung Galaxy Y
anupam_pb is offline   Reply With Quote
Old 01-06-2011, 04:16 PM   #2 (permalink)
Default Re: Is it RAM issue ?
Wait a little while before connecting. Wait for everything to load. A 5 min gap between booting and connecting will be enough.
Dont do anything like clicking the connection or any network related thing
thetechfreak is online now   Reply With Quote
Old 01-06-2011, 04:51 PM   #3 (permalink)
marvelousprashant's Avatar
Does not seem to be a RAM issue. Have you set up a lot of gadgets or startup program?
Download the trial version of TuneUp Utilities 2011 and run maintenance. Should solve your problem
HP Pavilion dv6-6017tx
i7-2630QM, 4GB RAM, 1GB Radeon HD 6770M. Very happy with this laptop because it makes an Apple fanboy go NUTS :shock: :razz::razz::razz::razz::razz:
Twitter : marvelprash
marvelousprashant is online now   Reply With Quote
Old 01-06-2011, 06:20 PM   #4 (permalink)
Game on !!!
anupam_pb's Avatar
Sometimes when the net gets disconnected, after that when i reconnect that time it happens usually. It never happened during first dialing after start up.
Sometimes aftr using my PC for a while (say for 15-20 min) then when i connect to net it may happen.
I'm having full version of tune up utilities 2010.
Old 03-06-2011, 04:17 PM   #5 (permalink)
Game on !!!
anupam_pb's Avatar
Actually i want to lower the burden on my GPU while gaming due to my PSU. I dont want improvements in graphics of the game.
So will an extra 2GB RAM lower the burden on GPU ?
Old 04-06-2011, 12:16 AM   #6 (permalink)
Super Moderator
asingh's Avatar
The RAM will not burden the GPU.
Only way you can reduce GPU burden, is to lower the resolution.
asingh is online now   Reply With Quote
Old 07-06-2011, 12:10 PM   #7 (permalink)
Game on !!!
anupam_pb's Avatar
Old 07-06-2011, 12:29 PM   #8 (permalink)
more like the case of crappy software driver.
Faun is online now   Reply With Quote
Old 07-06-2011, 12:30 PM   #9 (permalink)
Fullbring
Zangetsu's Avatar
@anupam_pb: whats the meaning of posting same question twice???
does it hang while doing anything else like watching movies,runing apps,games etc???
Old 07-06-2011, 02:47 PM   #10 (permalink)
Game on !!!
anupam_pb's Avatar
I postd it twice so that it could be seen in recent posts.
My PC does not hang while doin other activities.
My crysis 2 sumtimes hangs while resuming campaign bt not the PC
Old 07-06-2011, 02:55 PM   #11 (permalink)
use safe mode + networking and see if it hangs. Also try using non aero theme
Old 07-06-2011, 03:07 PM   #12 (permalink)
Wise Old Mouse
mrintech's Avatar
Are you using some sort of security software/firewall?
- MrinTech :)
mrintech is offline   Reply With Quote
Old 10-06-2011, 10:38 AM   #13 (permalink)
mithun_mrg's Avatar
It not a ram issue first update to latest version of vista service pack install all security updates to date, then install a good AV software update it and scan assuming ur r using PPPOE after that update ur lan card drivers and MB Bios if possible firmware of ur adsl modem
Lastly install the username & password in the modem and set it up to connect automatically so u wont have to dial up
mithun_mrg is online now   Reply With Quote
- by c4u
