hi all,
i was going throught portable hdd buy section in Forum and also seach In thinkdigit as well as on google for Buying help on seagate or WD portable HDD 500Gb.
My requirement.
1. 500 GB HDD.
2. Only USB ( No External Power supply)
3. Compatibility with higher data transfer way : firewire
4. Rigid one as my handling is Some what Poor...
my Rumors or Conceptions:
Transcend HDD are Low graded and have usually slow transfer rate and are thus cheaper,
anyways No No Transcend , only wd or seagate or iomega
My preference :
1. Seagate Freeagent Go Flex 500GB External Hard Drive (STAA500301)
rs : 3115/-
2. Western Digital Elements 500GB USB 2.0 Portable Hard Drives (WDBABV5000ABK)
rs : 3210/-
3. Iomega 500GB USB 3.0 Portable Hard Drive Red (35250)
rs : 3260
4. Western Digital My Passport Essential 500GB Portable Hard Drive (WDBACY5000ABK)
rs : 3485
5. Western Digital My Passport Essential 500GB Portable Hard Drive (WDBAAA5000AD2)]
rs : 3510
6. Western Digital My Passport Essential 500GB Portable Hard Drive (WDBAAA5000AD2)
rs : 3570
7. Western Digital My Passport Essential 500GB (WDBACY5000ASL)
rs : 3590
Iomega eGo BlackBelt 500GB USB2.0 Portable Hard Drive Black (34669)
Rs : 3865
3. Transcend 500GB Storejet 2.5 External Usb Hard Drive (TS500GSJ25D2)
rs : 3240
Points I consider/Confused .
1. if i go for Seagate HDD :i can have extension ports at backside of it which can change connectors (usb2,0 , usb 3.0, firewire etc)
2.Iomega eGo BlackBelt is comming with rubber case , does it protect well?
3. all time in forum people usually says Wd is Better then Seagate why?
Please help me buying it....
