Re: sparking sound and then shutdown
First OPEN your computer Cabinet and examine every part.
It seems to me, you are new to all this , if so, call or take it to the technician/shopkeeper you bought it from.
Regarding ur data, ask the technician to remove the hdd from the system and install the same in a test system and check for data. ( In most cases, the hdd will remain undamaged in such cases).
My guess is that the Graphics sub system on the mobo might have been blown off. if so, u will need to replace the mobo.
[Desktop]
[CPU] Intel C2D 2.4Ghz || [RAM] 2GB DDR2 || [VDU] Samsung P2370MS 23”|| [HDD] 500GB Seagate 7200RPM SATA || [OS] Mac OS X (Hackintosh)
[Laptop]
