Old 28-05-2011, 04:58 AM   #1 (permalink)
Unhappy Need Urgent Help.system Not Starting
hey guyz,just got a major problem up my sleeve.
i have purchased the following config
i7 2600k
msi p67A GD65-b3
gskill ripjaws X 8GB
corsair hx850(new RMAed)
2x 1TB hdd
gtx 580 lightning.
now this is the problem.
All leds on the board lightup.the cpu fan and other fans spin.then i get 3 random and 5 periodic beeps and no display.can anyone suggest any solution?tried putting individual sticks in each slot and yet same problem.plz help
coolgame is offline   Reply With Quote
Old 28-05-2011, 11:35 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Need Urgent Help.system Not Starting
Am sure the manual has beep codes listed. See if you can figure it out..!
asingh is online now   Reply With Quote
Old 11-06-2011, 10:38 AM   #3 (permalink)
mithun_mrg's Avatar
try to check ur video card try with a spare one if u have
mithun_mrg is online now   Reply With Quote
- by c4u
