Old 27-05-2011, 07:58 PM   #1 (permalink)
Default Connection From HDMI to VGA possible ?
I have screen play mx player with hdmi output. Can i buy a cable for HDMI to VGA.I have 22inch monitor with VGA & DVI input. Will this configuration work out ?
Parthiban is offline   Reply With Quote
Old 27-05-2011, 08:32 PM   #2 (permalink)
THE CHOSEN ONE
Blue Ripazah's Avatar
Default Re: Connection From HDMI to VGA possible ?
i have the same query
Blue Ripazah is offline   Reply With Quote
Old 28-05-2011, 01:09 AM   #3 (permalink)
Super Moderator
asingh's Avatar
Just check on ebay India.
HDMI to DVI.
asingh is online now   Reply With Quote
Old 28-05-2011, 12:42 PM   #4 (permalink)
Technoholik !!
Tech&ME's Avatar
First : Check your Monitor manual for setup instructions.
Second : DVI doesn't carry audio so you'll need to run audio separately.
[Desktop]
[Laptop]
Tech&ME is online now   Reply With Quote
Old 28-05-2011, 02:04 PM   #5 (permalink)
The Assassin
Cybertonic's Avatar
It will work or you can buy a converter for one of the ports but you will only get the performance of VGA/DVI not HDMI.
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 28-05-2011, 03:09 PM   #6 (permalink)
Technoholik !!
Tech&ME's Avatar
what will work dear ?
dude only Audio will not be carried, rest is all ok!!
And yes DVI doesnot support HDCP so NO FULL HD on this cable. Only a resolution upto : 1920×1200 or 2560×1600 that also if the DVI has all 24 pins.!!
[Desktop]
[Laptop]
- by c4u
