Old 26-05-2011, 10:30 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
ztbryan's Avatar
Default Acer Aspire 5536 Mic problem
Hi guys, i have an Acer Aspire 5536 running Win XP SP2. I can't seem to get the microphone, line in and stereo mix i.e. all the input sources are not working. Can anyone help me please ?
ztbryan is offline   Reply With Quote
Old 27-05-2011, 09:08 AM   #2 (permalink)
Default Re: Acer Aspire 5536 Mic problem
did you put mic in the pink/red port?
Or is it inbuilt?
thetechfreak is online now   Reply With Quote
Old 27-05-2011, 11:07 AM   #3 (permalink)
ztbryan's Avatar
the mic is inbuilt....even so it still doesn't work with an external mic
Old 27-05-2011, 11:16 AM   #4 (permalink)
Did you install properly install Audio drivers for it?
If yes, please try reinstall.
btw, what app are you using to record?
Old 27-05-2011, 11:59 PM   #5 (permalink)
ztbryan's Avatar
yep..ive tried it 3 times. i even downloaded the newest driver for it
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/141357-acer-aspire-5536-mic-problem.html
Acer Aspire 5536 Mic problem This thread Refback 15-11-2011 10:42 PM
- by c4u
