Old 26-05-2011, 07:13 PM   #1 (permalink)
THE CHOSEN ONE
Blue Ripazah's Avatar
Exclamation will the display quality be affected
my mobtherboard has a hdmi port but not my pc
if i connect my mobo with hdmi and then with a hdmi to dvi converter will the quality remain same
Blue Ripazah is offline
Old 26-05-2011, 07:31 PM   #2 (permalink)
Default Re: will the display quality be affected
Quality will remain the same.
HDMI and DVI are electrically same.
HDMI = DVI + audio.
and use proper font size when you post.
ico is offline
- by c4u
