Re: hdd SMART error ...help !!!
Originally Posted by saddy
hello .i have 250 GB seagate HDD about 5-6 months old .all of sudden i get a warning from windows that my harddisk is having a problem and i need to backup data .when i run AIDA 64 sytem utilites i did a SMART check on one this HDD it flashed this error msg.wat should i do .i think it may be due to bad sectors.can anyone expert on this issue help me .
Uploaded with ImageShack.us
When the HDD finds a read/write error, it will mark this sector as "reallocated" and transfer data to a special reserved area. That's why on a modern HDD you can't see bad blocks while testing the surface - all bad blocks are hidden in reallocated sectors
By Toejam31.
So i recommend u to back up imp data on that H.D to ur 2nd h.d
- SInce ur H.D is under warrrent send it for RMA
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
