Old 22-05-2011, 12:00 PM   #1 (permalink)
Default DVD Burning Issue
Hi guys
I have just purchased a new LG GH24NS70.. to burn disc i am using moser baer blank dvd. So far i have tried to burn 3 blank dvd's all divx movies. It shows that the dvd is created succesfully but when i try to play in all 3 disc it has made the same error out of 5-6 movies that burnt in a single disc it has failed to burn 1 movie in all the discs. i.e in the first disc it has 6 movies but it not play 1 movie the same story with the rest of the disc. Is this a hardware issue or software. for burning i am using LG burning tool that came free with the dvd writer. Has anyone faced this kind of problem. can somepne pls help me
Thanks
ak24 is offline   Reply With Quote
Old 22-05-2011, 01:05 PM   #2 (permalink)
Stuck in Time...
Vyom's Avatar
Default Re: DVD Burning Issue
So, from what I understood, you have tried to burn "the same six movies" on each of the three drives.
Sounds, like, the first movie is itself corrupt, on the source location, i.e., on the computer!
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 22-05-2011, 01:41 PM   #3 (permalink)
Nope they are all different movies not "the same six movies" and also i have watched those movies on my pc they work fine. I have noticed that in all the 3 disk it is the last file that has a problem.
Old 22-05-2011, 01:49 PM   #4 (permalink)
Stuck in Time...
Vyom's Avatar
Maybe a single disk is too short to hold six movies, and so the last one is left out, for burning.
Why don't you try just to burn 5 movies at a time.
Old 22-05-2011, 02:07 PM   #5 (permalink)
Tried burning just 5 files and then also 4 files it's doing the same thing. It says all files burnt sucessfully but fails to read the last one.
Old 22-05-2011, 02:58 PM   #6 (permalink)
Why dont you try using alternate burning software?
Can you burn other file?
Are dvd's scratched?
Are you trying to burn from admin a/c?
thetechfreak is online now   Reply With Quote
Old 22-05-2011, 07:22 PM   #7 (permalink)
saswat23's Avatar
And thats why i never prefer LG though many use it.
Now try burning 2 files at a time. If this problem stil persists then give it back for RMA. Also try convincing your dealer if he could exchange it for Samsung/HP/Asus DVD-RW.
Also try the steps mentioned in the above post by 'thetechfreak'.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 23-05-2011, 08:31 AM   #8 (permalink)
Tried to burn with Nero also a different file this time
dvd's are not scratched
yes i just have one account thats admin but still it says burned successfully but cannot read the last file .. vlc gives an error cannot read file. the dvd writer i have is 24x and dvd's are 16x could that be the problem. do i have to specify the burning speedlimit in nero ???
Old 23-05-2011, 08:52 AM   #9 (permalink)
Lg drives are arent that bad
I have been using one since 4-5 years and havent faced many problems.
but yes, some drives may have manufacturing defects hence the problems.
@OP
Nero normally burns in top speed.
I think you must try with lower speed. That should do it
Old 23-05-2011, 09:00 AM   #10 (permalink)
Stuck in Time...
Vyom's Avatar
I usually put a limit to 12x for burning a DVD.
Old 23-05-2011, 06:51 PM   #11 (permalink)
How do you manually lower the speed in Nero 7
Old 23-05-2011, 07:05 PM   #12 (permalink)
got img from google img search , i personally dont use Nero ,
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
Rajesh345 is offline   Reply With Quote
Old 23-05-2011, 08:40 PM   #13 (permalink)
Stuck in Time...
Vyom's Avatar
Or if OP uses Nero Burning ROM mode, (that is, non-express mode) then he can select, Recorder -> Burn Compilation.
And then at Burn tab, selecting speed at write speed drop down menu.
Old 23-05-2011, 08:43 PM   #14 (permalink)
Project Halcyon V2.0
tkin's Avatar
Hi guys
Thanks
Burn moserbaer dvds @ 8x max, also do a verification run.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 23-05-2011, 08:48 PM   #15 (permalink)
Stuck in Time...
Vyom's Avatar
Oh, yeah... I completely forgot to suggest this. Verification is Absolutely Must here. It might take some time more, to finish the burn process, but it's worth it.
Since, many times, data is burned successfully, and it is at the time of verification, that I find out, that some files were not burned correctly.
Saves my a** many times
Old 23-05-2011, 11:11 PM   #16 (permalink)
This sounds like a software issue. Try alternate burning software - DVD Author Plus is a good free dvd burning software. It will burn your video files to create a Video DVD that will work on any DVD player. Easy to use, works perfectly, and fast. Download it here:
Free DVD Burning Software - DVD Author Plus
adam is offline   Reply With Quote
Old 23-05-2011, 11:21 PM   #17 (permalink)
tkin's Avatar
Most simplest 1 shot burner: CDBurnerXP: Free CD and DVD burning software
Old 24-05-2011, 07:43 AM   #18 (permalink)
I think the source location is corrupted...
Srithilak is offline   Reply With Quote
Old 24-05-2011, 08:20 AM   #19 (permalink)
I'll tell you a simple thing regarding optical drives. Everyone has faced problems with every brand. No point of being brand conscious.
In the old days, Samsung drives never used to open. I replaced those with Lite-On and Lite-On was too noisy. Then father bought a HP media center PC and its DVD writer went poof within a year. I replaced my Lite-On DVD Writer with a Sony and Sony also went poof within a year. It also had trouble while reading few DVDs which was resolved by a firmware upgrade. Now the Superdrive of Mac mini is also giving me problems.
Old 24-05-2011, 10:54 AM   #20 (permalink)
Hey guys
This time i used nero and burnt the disc at 8x also selected verification run. It took sometime but burnt the disc correctly. Thank you everybody for your help
Old 24-05-2011, 11:37 AM   #21 (permalink)
d3p
"Official HD 7970 Owner"
d3p's Avatar
Glad to know your problem was resolved. If possible then give imgburn a try, simple, effective & freeware...
Sapphire HD 7970 Unboxing
i7 2600k|Ma IV Ex-Z|Venomous X RT - CM R4's Push Pull|16GB RipjawX|Sapphire HD7970 OC, PhysX - Palit SP GTX570|OCZ Vertex 3 120GB|WD Black Raid 0, 40GB[Lisa]|AX850w|Asus Xonar DX, VK278Q|HAF 932|NZXT Sentry II| Logitech G27 Racing Wheel, G15, Attack II-HandBrake, HD C310|Razer DA|Bose Over Ear HP|Powershot HX40IS||E7-00|
IRC Krow
d3p is offline   Reply With Quote
Old 24-05-2011, 01:21 PM   #22 (permalink)
tkin's Avatar
I've tried LG, Samsung, Sony, Lite-on(moserbaer now afaik) and all sucked, now I've bought an Asus, its working good(2 months), you might wanna try one next time.
Old 24-05-2011, 09:36 PM   #23 (permalink)
Stuck in Time...
Vyom's Avatar
Hey guys
Wow.. at 8x... it ought to be damn... SLOOOooooWWwwWWww :zzzz:
But glad, that it worked
Also, @tkin: I have used, LG and Samsung in the past... but now I am using HP. It did costed me couple of hundred rupees more, but the damn thing even survived, after a CD got KA-BOOM and shattered inside the drive! Now that's I call, HeavyDuty!
- by c4u
