I have AMD Athlon 5200 CPU and it has been running quite fine over the last 3 years, but now recently it has developed an overheating issue!
Even thought the fan is on at full speed 3200 RPM still the temp is sometimes shooting upto 75-80 degrees while even playing a song, or browing the net for some time!!
My config is Nvigia 8600GT graphics, 2GB ram DDR2, 1TB HDD,
In all this, the GPU seems to have no problem, and runs cool at 60-65 degrees as usual.
What may be the problem? Has the internal temp sensor gone bad?
Should I just upgrade to AMD Athlon II X2 260?
My Motherboard is MSI K9AGM4.
It is an AM2 motherboard, but the BIOS update says it supports AM2+, but in the CPU support, it says Athlon X2 only max, so am confused whether the new new CPU would run or not?
Please Help.
