Pixelated/Grainy video playback, washed out screens in Asus M4A78LT-M LE
I just had a budget system built with Asus M4A78LT-M LE motherboard which comes with integrated graphics Radeon 3000. This board was manufactured on Jan 2011 with Bios version 0704. I installed windows xp and all the drivers. The problem is the videos(movies, youtube, everything) play pixelated and grainy on my 17inch Samsung crt monitor. Connected to another monitor(tft), same problem. Downloaded and installed new/old drivers, no change. Yeah, i installed and uninstalled k-lite codec pack, used driver sweeper to remove leftover drivers, no solution. I played in different video players, changed vlc's video output to direct 3d, opengl, etc.. still pixelated.
Even the screen itself is not as clear as my 10 year old intel 815 graphics, looks kind of washed out. I am searching a solution from two days, haven't found any.
Is there problem with integrated gpu hardware? What should i do now?
Re: Pixelated/Grainy video playback, washed out screens in Asus M4A78LT-M LE
Asus M4A78LT-M LE (Radeon 3000 graphics integrated)
Amd Athlon x2 250
Transcend 2Gb
500gb Hitachi
LG dvd writer
Mercury Matrix cabinet with Mercury 450w smps
aren't the drivers which ship with motherboard supposed to work for basic stuff like video playing etc... I will try Catalyst 11.5 but the integrated card itself is quite old, so i doubt it will help. I have already tried few other versions, none have helped. Everything has been so dull looking in this computer so far.
I think northbridge/igp has to be the motherboard temperature right?
Motherboard temp - 34 c
cpu temp - 39 c
vcore voltage - 1.392 v
3.3v voltage - 3.296 v
5v voltae - 5.120 v
12v voltage - 12.099 v
cpu fanspeed - 3292 rpm
Originally Posted by asingh
Please try the latest mobility driver and CCC from the official site.
I think in most of the CRTs the VGA cable is permanently attached. OP has also tried on a TFT monitor with similar results. Looks like either a corrupted Windows installation or some hardware problem.
yeah monitor issue is ruled out. my crt monitor has permanent vga cable which works fine with external tv tuner box giving clear videos.
i am installing windows 7 tomorrow to confirm if its a hardware problem.
And also install the latest catalyst 11.5 drivers.
I installed Windows 7 and still face the grainy display problem. Both in winxp and windows 7 i get a 0.25 sec synchronization problems in videos plus the pixelation/grainy playback. The problem is definitely the integrated graphics hardware.
I heard complaints of the distributor of Asus, rashi pheriperals purposely don't RMA. I'm sure my vendor will handle this case but should i attach a letter describing the problem and how long will they take to give back a new motherboard?
Asus just returned the motherboard saying there is "No Defect". But there is definitely problem with the videos. All these days i was using my brothers Intel 965 computer with my monitor which was awesome. I definitely cant live with this board, what should i do now guys?
The video is not so bad, so it might not show up in a screenshot. I just tried a screenshot from bsplayer, but it came out small. Is there any video player which gives full screen screenshots?
I will try Linux mint in the next two days. but let me tell you the same videos look very good in intel 965 and my old intel 815.
