Old 19-05-2011, 06:20 PM   #1 (permalink)
THE CHOSEN ONE
Blue Ripazah's Avatar
Angry is my smps faulty
my pc cabinet is giving me electric shocks only the back panel is havng full current
i tested it with a tester and the light was on....that means either my smps is faulty or any other problem the wires are duly inserted in the parts....
Blue Ripazah is offline   Reply With Quote
Old 19-05-2011, 06:27 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: is my smps faulty
Get your earthing checked.
asingh is online now   Reply With Quote
Old 19-05-2011, 07:04 PM   #3 (permalink)
TDF Sucks
are you plugging your PC to socket with 2 pin plug?
thats the biggest reason for shocks.
TDF Sucks.
Extreme Gamer is offline   Reply With Quote
Old 19-05-2011, 07:28 PM   #4 (permalink)
saswat23's Avatar
I too had this type of problem. I used to get shock on my cabinet's back panel and monitor's screen.
The problem is due to erathing. So, check it and re-earth.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 20-05-2011, 03:03 PM   #5 (permalink)
THE CHOSEN ONE
ohk thnx .......
Old 20-05-2011, 03:34 PM   #6 (permalink)
Dust in the Wind
Skud's Avatar
definitely an earthing problem. get it checked.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
- by c4u
