Old 19-05-2011, 10:48 AM   #1 (permalink)
Neophyte
Default Pc won't start-just blink
I am Wrkng in Guwahati as a graphics designer, my office pc wouldn't start and after unplugging and plugging the power cable few time after 1 or 2 hrs it will start up.I think its a branded assembled pc of Raven cost 1.5 lakh...
If I press the power switch it will just blink bt won't start...then i will unplug it & do the same & it won't start....
I am guessing what it problem might be coz i changed the power cable, checked the internal wires, changed the ram sloths. Nothing worked..:
PLZ GIVE SOME SUGGESTIONS...
manab_bikash is offline   Reply With Quote
Old 19-05-2011, 02:30 PM   #2 (permalink)
Wise Old Ghoul
Piyush's Avatar
Default Re: Pc won't start-just blink
does it happens that when you press the power button , the fans,LEDs star for seconds and then all of it stops
and sometimes nothing happens(not even LED/fans start)
btw check your PSU with some other system
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 20-05-2011, 10:41 AM   #3 (permalink)
Neophyte
Yeah... Its exactly what is happening... the fans, LEDs doesn't even start just blink... and it stops...
Old 20-05-2011, 11:41 AM   #4 (permalink)
Hmmmmm
Tenida's Avatar
I have also faced the same problem few month ago.To resolved the problem i clean the ram slot and ram the golden edges with soft cloth.And reset the bios jumper.Afterthat the problem gone.Hope that you will solve ur problem soon.Best of luck.
Tenida is offline   Reply With Quote
Old 20-05-2011, 03:57 PM   #5 (permalink)
Wise Old Ghoul
Piyush's Avatar
i had exactly the same problem
motherboard turned out to be culprit
and it NEEDS to be changed
also do tell your PSU model/brand
--Get Backers
Old 21-05-2011, 02:56 PM   #6 (permalink)
Neophyte
Actually, the technician came to know where or what caused the problm.
The PSU have 2 outlets to the Processor...if the 2 were connected 2gethr..the PC won't start..but when it is tested Singly...it starts..
So, they & I both thought that its the PSU that's unable to supply the power....
Bt I also think MBrd is having trouble collecting the power..
& Sorry They took the PSU with them 2 check...
Old 21-05-2011, 05:27 PM   #7 (permalink)
2 outlets to the processor? are you talking about the 12V EPS cable?
Old 22-05-2011, 11:28 AM   #8 (permalink)
Neophyte
Sorry I can't ans 2 that coz when i came 2 office 2day the whole system was gone...
Maybe the PSU is okay the Board is having the problem....
Old 25-05-2011, 05:00 PM   #9 (permalink)
Also had the same problem so i eventually gave up and took it to the shop, turned out i had an extra brass stand off in my motherboard and it was causing it to cut off. worth a look?
Parkerbwee is offline   Reply With Quote
- by c4u
