Old 18-05-2011, 11:26 PM   #1 (permalink)
Aj12's Avatar
Exclamation Will This Ram Fit ??
Does anyone know if the Corsair Vengeance 8GB (2 x 4GB) CMZ8GX3M2A1600C8
would fit using the Nocua NH-U12P SE2 cooler & ASUS P8P67 DELUXE B3 Revision (REV 3.0) Motherboard??
Case : Corsair graphite 600t (which would not be a problem , i guess??)
I need to know if the RAM will fit with this mobo/fan combo
Can someone please confirm.
Thanks.
Aj12 is offline   Reply With Quote
Old 18-05-2011, 11:32 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Will This Ram Fit ??
You can check the clearance here.
Noctua.at - sound-optimised premium components "Designed in Austria"!
asingh is online now   Reply With Quote
Old 18-05-2011, 11:38 PM   #3 (permalink)
Aj12's Avatar
uh could you please confirm
Old 19-05-2011, 12:38 AM   #4 (permalink)
Super Moderator
asingh's Avatar
Not able to find the height of the heat spreaders.
Old 19-05-2011, 09:39 PM   #5 (permalink)
Aj12's Avatar
i couldnt find it either!!
Could someone please confirm if this cooler/ram combo would be compatible ASAP!!!
Coz i have to finalize the parts for my build...
Thanks.
Old 19-05-2011, 11:59 PM   #6 (permalink)
Dust in the Wind
Skud's Avatar
may be this link will help:-
The Corsair Support Forums - Vengeance compatible with NH-U12P SE2 heatsink?
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 20-05-2011, 12:03 AM   #7 (permalink)
Super Moderator
asingh's Avatar
Seems risky this combination.
Old 20-05-2011, 12:33 AM   #8 (permalink)
Aj12's Avatar
guys i found this picture ..
http://imageshack.us/f/21/dscf2967e.jpg/
same motherboard and all but different ram which is 8 Gigs of Gskill Ripjaws X DDR3
i think i can get away wit 8gb of vengence buy using the "BLUE " color coded dual channel slots (A2 and B2) as the cooler covers the first "BLACK" slot(A1) thus making slots
(A1 and B1) unusable.
or so i think..
anyway your thoughts on this....
Old 20-05-2011, 12:39 AM   #9 (permalink)
Dust in the Wind
Skud's Avatar
yeah, you have to let go the 1st mem slot, that's it...
Gaming Rig:
HTPC Rig:
Old 20-05-2011, 06:24 AM   #10 (permalink)
TDF Sucks
go to corsair.com.
there open any RAM page and go to FAQ section.over there you will find the height
I checked and it was 2.07" = 52.5mm for your RAM.its shorter than standard fin dom and dom gt series
TDF Sucks.
Extreme Gamer is offline   Reply With Quote
Old 25-05-2011, 12:14 AM   #11 (permalink)
Treatment in progress...
mukherjee's Avatar
Have a look at this post
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline   Reply With Quote
- by c4u
