Old 16-05-2011, 05:40 PM   #1 (permalink)
THE CHOSEN ONE
Blue Ripazah's Avatar
Default front audio jack not working
my pc's front audio jack not working
the wire is properly conected to the mobo
Blue Ripazah is offline   Reply With Quote
Old 16-05-2011, 07:17 PM   #2 (permalink)
Never give up!!
jerrin_ss5's Avatar
Default Re: front audio jack not working
did you check your microphone !!!
and did you install the sound driver ??
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 16-05-2011, 09:11 PM   #3 (permalink)
Stuck in Time...
Vyom's Avatar
Jacks on the front usually don't work, atleast in most of the cases I have experienced.
If you have a USB port also, along with the audio jack, in front of the PC, then check if that works or not. If the USB is working (like you can read Pen drives through it), and the jack at the back is working, then the issue is most probably with the front jack.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 16-05-2011, 09:37 PM   #4 (permalink)
127.0.0.1
mitraark's Avatar
Actaully you have to change something in the BIOS after that it works , wait i will check what i did with my Gigabyte motherboard and tell , can;t exactly remember what i had done.
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
Old 17-05-2011, 01:09 PM   #5 (permalink)
RAMPAGE!!!!
modder's Avatar
Yes you're absolutely right. Its Intel HD Audio/AC' 97.
AC' 97 is the compatibility mode (you've to set it in BIOS), most cables/audio headers coming with cabinets are for outdated AC' 97 not the newer Intel HD Audio.
Desktop Boards — Troubleshooting audio issues
Some cabinets come with both:
modder is offline   Reply With Quote
Old 17-05-2011, 01:54 PM   #6 (permalink)
saz
saz's Avatar
I had this experience with my Gigabyte Motherboard where the front audio jacks were not working and I just had to enable the front audio jacks using the Realtek Audio control panel....!!!
AMD Phenom II X4 955 | GA-880G-UD3H | 2X2GB Corsair 1333Mhz | Segate 500 GB + WD 500 GB | Corsair H50 | HD6770 |Tacen Supero 500W | CM430
saz is online now   Reply With Quote
Old 17-05-2011, 03:24 PM   #7 (permalink)
THE CHOSEN ONE
how can i change the setting in my bios i hv gigabyte h55m d2h mobo
- by c4u
