Old 15-05-2011, 08:54 PM   #1 (permalink)
StrYker_BLACK_E's Avatar
Default Thermal compound query
Hi,
Please suggest the best performing thermal paste available online.
Budget is under 1k.
Thanks.
The Black Edition
Phenom ll X4 955 BE|Hyper212+|Asus M4A785TD-V-EVO|GSkill 2x4GB 1600mhz|WD CavairBlue 500GB|HD6850Xfire|Corsair GS800|Razer Death Adder|Goliathus|VA2038wm|5x120mm Red LED+230mm| Thermaltake V9series
Xperia Neo V|N81 8GB|iOmega ScreenPlayHD 500GB
StrYker_BLACK_E is offline   Reply With Quote
Old 15-05-2011, 09:56 PM   #2 (permalink)
Adam young
sukesh1090's Avatar
Default Re: Thermal compound query
i think this is good for you,
eBay India: Arctic Silver 5 3.5g gram Thermal Paste Grease 20 uses (item 390128324152 end time 31-May-2011 07:44:59 IST)
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 16-05-2011, 04:51 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
you can also give CM Nano Fusion a try - my personal favorite
ToPsPeEeD = FaSt BuT StEaDy
Old 16-05-2011, 06:30 AM   #4 (permalink)
Never give up!!
jerrin_ss5's Avatar
i recently brought a paste from cooler master for 150 bucks they provide you with different templates and a spreader for optimal spreading of paste
check that out
i can't remember the model no. though !
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 17-05-2011, 08:08 PM   #5 (permalink)
Guys, I found these two products:
1.Sunbeam TX-4 &
2.CoolerMaster Ice Fusion.
So, which one shall I go for?
The Black Edition
Old 17-05-2011, 08:47 PM   #6 (permalink)
TDF Sucks
niether.try to get OCZ freeze or Arctic MX-4
the two you mentioned are horrible.
TDF Sucks.
Extreme Gamer is offline   Reply With Quote
Old 17-05-2011, 09:01 PM   #7 (permalink)
Okay. I think OCZ freeze will be available from Techop.in but what about the Arctic MX-4??how much does it cost and can you please give me a link to buy this product online, just in case the OCZ isn't available?
The Black Edition
Old 17-05-2011, 09:15 PM   #8 (permalink)
Super Moderator
asingh's Avatar
itdepot has TIMs.
asingh is online now   Reply With Quote
Old 17-05-2011, 09:31 PM   #9 (permalink)
Okay,thanks everybody for your help.
The Black Edition
- by c4u
