Old 15-05-2011, 08:52 PM   #1 (permalink)
Default DDR2 to DDR3 RAM. Is it worth the upgrade??
I have current system that runs 6Gigs of DDR2 RAM at 1066MHz. The CPU is a Core 2 Quad Q6600 @ 2.4GHz.
lately I have been thinking about upgrading to 4GB of DDR3 RAM but that would mean I will also have to change my motherboard.
a 4gb ddr3 module from transcend costs about 2200. is it really worth upgrading??
amitbhawani is offline   Reply With Quote
Old 15-05-2011, 09:35 PM   #2 (permalink)
Adam young
sukesh1090's Avatar
Default Re: DDR2 to DDR3 RAM. Is it worth the upgrade??
i don't think so. comparing 6gb and 4gb.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 15-05-2011, 09:42 PM   #3 (permalink)
saswat23's Avatar
There is no need at all. Stick with the current setup. Upgrading will cost you un-necessarily for just a mere frequeny increase.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 16-05-2011, 04:53 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
yep, stick with DDr2 rams - if you need a boost in performance then OC the CPU to 3.5-3.6 Ghz using a good CPu cooler like CM Hyper 212+ though the OC will depend on your mobo.
ToPsPeEeD = FaSt BuT StEaDy
Old 16-05-2011, 06:28 AM   #5 (permalink)
Never give up!!
jerrin_ss5's Avatar
just wanted to know if it depends on mobo
what are the factors looked upon and can i overclock with my mobo
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 16-05-2011, 09:58 AM   #6 (permalink)
ok i am sticking with my good old 6gb ddr2.
just out of curiosity though, what about, 4GB DDR2 vs 4GB DDR3. Any significant performance improvement??
Old 16-05-2011, 10:00 AM   #7 (permalink)
blademast3r's Avatar
When you overclock u generally overclock the FSB frequency.. This is the bus to which ur northbridge components (RAM,CPU) are connected. So yes, your rams will work faster too..
And abt ur original qestion..No, you wont see a significant boost.. However ull be able to OC more usng a higher frequency DDR3
blademast3r is offline   Reply With Quote
- by c4u
