Old 14-05-2011, 03:23 AM   #1 (permalink)
cute.bandar's Avatar
Default cheapest silent case fan ( 80mm/90mm )
my temps are going really high; 90+ @ load . However If I remove the side panel , the max drops to 78C . This suggests that a case fan would really help my temps.
But I am paranoid about extra sound coming from my PC. any suggestion for cheap cheap silent 80mm/90mm case fan ?Also how loud are generic case fans ?
Thanks
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
cute.bandar is offline   Reply With Quote
Old 14-05-2011, 03:36 AM   #2 (permalink)
pulkitpopli2004's Avatar
Default Re: cheapest silent case fan ( 80mm/90mm )
which cabinet you have?
configuration?
I'd explain it to you, but your brain would explode... Trust me :hot:
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB Caviar Black
pulkitpopli2004 is online now   Reply With Quote
Old 14-05-2011, 09:55 AM   #3 (permalink)
generic cabinet.
config:
AMD X2 4000+
1 gb ram
m2n68-am SE2
HD4670 1gb
280W VIp PSU ( I know )
Old 20-06-2011, 11:46 AM   #4 (permalink)
mithun_mrg's Avatar
78C if processor temp is still high adding a cheap 80mm case fan won't make much of a difference rather install a Coolermaster Hyper TX3 1.2K
Coolermaster Hyper TX3 CPU Cooler - Model RR-910-HTX3-G1 ― Lynx - The Audio , Electronics And Computer Online Store In India
BTW use Real temp to monitor ur temps
mithun_mrg is online now   Reply With Quote
- by c4u
