Old 11-05-2011, 11:44 PM   #1 (permalink)
arian29's Avatar
Arrow 5.1 speakers and card
I am thinking of buying the Creative T6060 5.1. Do i need to buy a 5.1 sound card also or is the on-board sound card good enough?
http://www.twitter.com/arian29
ScAn My AvAtAr
arian29 is offline   Reply With Quote
Old 12-05-2011, 02:10 PM   #2 (permalink)
RAMPAGE!!!!
modder's Avatar
Default Re: 5.1 speakers and card
The on-board sound card will do just fine
modder is offline   Reply With Quote
Old 12-05-2011, 02:23 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
depends on what mobo you have. T6060 is decent set of speakers. if possible, get a Creative Live! 5.1 atleast to take the load off the CPU.
desiibond is offline   Reply With Quote
Old 12-05-2011, 02:58 PM   #4 (permalink)
Bang! Bang!
noja's Avatar
I've heard creative soundcard's have some driver issues on windows7 like mp3 2ch to 6ch.
I don't know if this has been solved or not.
noja is offline   Reply With Quote
Old 13-05-2011, 12:50 AM   #5 (permalink)
MegaMind's Avatar
Get Creative Audigy value... Good card than Creative Live!...
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 11-06-2011, 11:49 AM   #6 (permalink)
mithun_mrg's Avatar
beware creative audigy bass redirection does not work in windows7 so Win7=No Bass dont know about 5.1 its a pity that we don't have many choices in india regarding sound cards
Lynx India are selling Audiotrak sound cards don't know how they are but u can have a look at their website
mithun_mrg is online now   Reply With Quote
- by c4u
