Old 10-05-2011, 09:04 AM   #1 (permalink)
cute.bandar's Avatar
Default Need to buy a mini ups kind of thing
Just want 10 minutes power backup for the router and modem. Something like this
Want from a reliable company.
If possible should be small form factor .
Any advice ? where in delhi could I get one ?
Thanks
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
cute.bandar is offline   Reply With Quote
Old 10-05-2011, 10:15 AM   #2 (permalink)
Default Re: Need to buy a mini ups kind of thing
Whats your budget? Why dont you get a full fledget UPS like a APC 600VA for around Rs.1500
thetechfreak is online now   Reply With Quote
Old 10-05-2011, 10:47 AM   #3 (permalink)
Budget is not an issue(the UPS is for someone else in family)
I'll eventually go for the APC if I find nothing. But right now for just a modem and router it is a major overkill.
Old 10-05-2011, 10:50 AM   #4 (permalink)
Bang! Bang!
noja's Avatar
If you have good knowledge on soldering and electronics then you can build your own. Just get a cheap ups kit from the local electronics spare parts dealer [its got all the instructions] solder it use a battery of your choice. DONE.
battery size will determine the backup time. bigger the battery bigger the backup. Greater load will require higher capacity components in the ups circuit. But your requirement is quite very less.
noja is offline   Reply With Quote
Old 10-05-2011, 10:57 AM   #5 (permalink)
@noja , that sounds like fun, I would probably do that if it were my own system. But since I am getting this for someone else. I'll need something reliable..
Old 10-05-2011, 11:12 AM   #6 (permalink)
Bang! Bang!
noja's Avatar
better get a regular ups then.
My 600va V-guard ups gives 30minutes backup for my 40w lcd monitor connected and creative inspire m2600 simultaneously.
Old 10-05-2011, 03:54 PM   #7 (permalink)
As you want for router, get the cheapest ups you can find.
Old 10-05-2011, 04:40 PM   #8 (permalink)
saswat23's Avatar
Yes, Zebronics700 600Va UPS is available for 1k. Get that.
It will be sufficient.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 10-05-2011, 05:45 PM   #9 (permalink)
Any comments on this mini UPS: Varsha Products - Battery Back-ups / Mini Ups (scroll down)
Edit: nvmind I called them , its expensive Rs. 1500 . Seems will have to go with the zebby UPS.. I dealer quoted 1.1k for the zebby UPS in nehru place btw..
Old 10-05-2011, 05:56 PM   #10 (permalink)
iDota
Sarath's Avatar
I was going to suggest something and suddenly realised that even i needed one for my router for smooth (no disconnections) operation during online play.
The only thing that held me back was getting one for my PS3 and another one for the router seemed a lot of money for a 600VA APC each.
I didnt know there were 1k UPS available. Are they reliable? i know just a router but even otherwise.
Sarath is offline   Reply With Quote
Old 10-05-2011, 05:58 PM   #11 (permalink)
Yeah. I reccomend to go for whatevers cheap.
Router wont need much power.
Old 10-05-2011, 06:05 PM   #12 (permalink)
iDota
Sarath's Avatar
I almost know the answer myself but let me still try.
i had a UPS for a desktop i think V guard a few years back (5y?). Will it still work? The battery would have most likely died and i fear destroyed the unit itself (leakage etc)
SO my ques:
1.Better to get new UPS?
2.Get a new battery for old V-Guard UPS?
sry for hijacking someone elses thread
Old 10-05-2011, 07:28 PM   #13 (permalink)
saswat23's Avatar
Try changing the battery, it will cost you 500-600 bucks only.
Old 11-05-2011, 02:29 PM   #14 (permalink)
OK I have decided to go for a standard 600VA UPS, since nothing else is available. Just one last thing: small form factor. Budget is stretchable, but the table in which the UPS will be kept is not . So please suggest a UPS with small dimensions.
Thanks
- by c4u
