See in taskmanager if there is a process called regvsr.exe. Its one of most common processes that keep utilisation 100%.
If there is, you are infected with virus.
Ya he is right. Check for unwanted programs in the task manager and end that process. regsvr.exe is a type of virus, so scan your PC with a good anti-virus.
__________________ GPS: The best way to navigate safely and securely.:smile:
I killed a few running processes but many a times killing some used to cause my pc to hang so i refrained from killing most of them.
I am using a core2duo lappy, 3gb ram, 250GB, a decent ati card.
It is running cool and utilisation is under 20%. I have F secure anti v got it free from airtel.
I will scan for viruses.
