my brother in law is having problem with his simpletech portable drive.
avast is blocking : autorun.inf(says infected with inf:autorunax(wrm)
and e5188982.exe infected with win32: inject-agc(trj).
he cant acces the drive and the data please suggest what to do.
please reply immediately if any one is online at this hour.
the drive details:SimpleTech SimpleDrive 1 TB 96300-41001-170
thanks in advance
hoping for prompt reply
aby
Uninstall avast or disable it's gurad and Use Panda USB Vaccine - it will block any potential malware which tries to inject into system using autorun files - copy the needed contents - format the drive and install a anti virus program again / enable it's gurad - run a full system scan.
if on XP
keep pressing shift key while attaching the drive(it will disable autorun)
then you can scan and remove the virus.
I dont know will it work on 7 or vista
Keep the faith, not here to win trophies, not here to win the league, only here to show people how we play.... ARSENAL!!!!!!!!!!!!!!!
one more thing, his drive is full with 1 tb of imp data, so how can he back it up before formatting. can he safely backup data after using panda usb vaccine?
You don't need to format it in the first place if you've imp. data on it.
1. Remove the infected files using a good AV
2. Run>CMD
3. type '<drive letter goes here>:' [eg, C: OR D:] > 'enter'
4. type 'dir' > enter
5. see if 'autorun.inf' is listed, if exists
4. type 'del /f autorun.inf'
(without quotes and <>)
Done. Use any file except executable (*.exe) or shellexec (*.com/*.bat/etc) ones not before thoroughly scanning them
humm the autorun.inf is not being listed. if i just access the drive every apppears as a link and theres also avira.lnk there but my brother in law says he hasnt ever used avira.
even if someone must have put avira in his drive what is this link problem can you guys help with this please.
"Vulnerability in Windows Shell Could Allow Remote Code Execution", don't view the drive. It infects/get executed just by viewing/when windows draws the icons.
See if KB2286198 shows in windows updates list in control panel, if it doesn't:
If you're using Win7 SP1 then you're safe as KB2286198 is included in it. If you're using Win 7 and haven't installed SP1, its always better to get it/install it.
Hey Sudheesh! I had the same problem too. Actually, your hard drive is not infected. Your operating system is infected with a malware. You just have too re-install Windows 7 or any other operating system you want. Then in that operating system also you'll see the shortcut folders. Delete Them. On the Menu Bar, go to Tools-->Folder Options...-->View. Click on 'Show hidden files, folders and drives' and on 'Hide protected operating system files.' A Warning dialog box will pop up. Click on yes. Then you'll see all your folders (NOT shortcuts) permanently hidden. You'll just have to make new folders, move all files from your permanent folder to the new folders you've created and then delete the permanently hidden folders. Unplug and then again plug-in your drive. You'll not be able to see any of the shortcuts. All your files are back in normal folders. Enjoy!!
Avast autometically detects any autorun.inf as virus. For example, try to make a autorun.inf by yourself & run avast scan in it.
Solution: get rid of avast or disable autorun in your PC.
