Old 06-05-2011, 08:38 PM   #1 (permalink)
antani_90's Avatar
Default Ram Prob
hai guys...help me sort out...bought a new mobo asus p5g41c m-lx,i installed a corsair xms2 2gb ddr2 800mhz ram(recently rma'd hence new) but the system wont boot....tried with my old 2*1gb ddr2 667mhz ram,system works an everythin is fine...is there a prob with my rma'd ram....using new psu,no problem with the rest of the rig so far.....'m confused help me out guys...
My rig.
Intel c2d E7200,
Asus p5g41c m-lx,
2 gb ddr2 667mhz ram,
500gb hdd,
1 dvd rw drive,
coolermaster ep 460 watt
antani_90 is offline   Reply With Quote
Old 07-05-2011, 11:00 AM   #2 (permalink)
Default Re: Ram Prob
Try using the RAM with another PC if possible.
Try using the new RAM a single stick at a time to see if it works then.
thetechfreak is online now   Reply With Quote
Old 07-05-2011, 03:08 PM   #3 (permalink)
Living to Play
gameranand's Avatar
If you are putting the RAM correctly in the slot and it doesn't work then I guess the RAM is faulty.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 07-05-2011, 03:30 PM   #4 (permalink)
Dust in the Wind
Skud's Avatar
Do as thetechfreak said and post back.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
- by c4u
