Old 05-05-2011, 09:59 PM   #1 (permalink)
avichandana20000's Avatar
Default Problem in front panel
I am having CM ELITE 310 and am using for the last one and half years. every thing is fine. But the audio jack in the FRONT PANEL is not working. But the USB ports are working fine.
Can I change only the FRONT PANEL ?
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is online now   Reply With Quote
Old 06-05-2011, 12:11 AM   #2 (permalink)
saswat23's Avatar
Default Re: Problem in front panel
how can u change the front panel dude. Its not of any use.
Check if the cable of the front audio coonector is plugged properly inside the cabby. Else try and change the cable, it might be faulty.
But are ur audio connectors at the back working fine..???
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 06-05-2011, 12:16 AM   #3 (permalink)
Super Moderator
asingh's Avatar
Contact CM service. At times they ship it free.
asingh is online now   Reply With Quote
Old 10-05-2011, 08:39 PM   #4 (permalink)
Back panel is working absolutely fine.
i am asking whether this (refer attachment) is available ?
Old 10-05-2011, 09:21 PM   #5 (permalink)
RAMPAGE!!!!
modder's Avatar
Was it working before?
Is there any option in BIOS saying: 'Intel HD Audio/Azalia' or 'AC'97' ?
Try swapping the ^options>save sett.>see if the front aud. works
modder is offline   Reply With Quote
Old 10-05-2011, 09:27 PM   #6 (permalink)
Dust in the Wind
Skud's Avatar
Was it working earlier? Either a loose connection or some driver settings need to be changed provided there are no physical damage.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 13-05-2011, 07:52 PM   #7 (permalink)
it was working earlier. actually when i insert the jack somtimes a very thin sound comes and sometimes no sound is there at all.
i think it is a case of loose connection.
- by c4u
