Old 05-05-2011, 07:47 PM   #1 (permalink)
Adam young
sukesh1090's Avatar
Default power supply for 2k
guys i want too buy power supply unit for my future 6670.so which one should i buy.my budget is 2k.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 05-05-2011, 09:02 PM   #2 (permalink)
Living to Play
gameranand's Avatar
Default Re: power supply for 2k
I would suggest to up your budget because at that budget you won't get a decent PSU. I would suggest Corsair 450W.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 05-05-2011, 09:47 PM   #3 (permalink)
FSP SAGA II 500W @ 2k is the best deal and it is more than enough for your current config and the future graphic card.
AMD Athlon II X4 635 || Asus M4A78LT-MLE || Kingston 2X2GB 1333MHz DDR3 || WDC Green 500GB || CM Elite 310 || Dell E2010H
manujohn is offline   Reply With Quote
Old 08-05-2011, 02:14 PM   #4 (permalink)
Where's my M4A1
at 2k FSP SAGA II 500W is best. But to be future proof go for Corsair 450W
Keep the faith, not here to win trophies, not here to win the league, only here to show people how we play.... ARSENAL!!!!!!!!!!!!!!!
1993gregory is offline   Reply With Quote
Old 09-05-2011, 03:10 PM   #5 (permalink)
Adam young
sukesh1090's Avatar
thank you for the reply guys.and what about this psu
TheITWares - One Stop for all Gizmos!CORSAIR Builder Series CX430 CMPSU-430CX 430W ATX12V Active PFC Power Supply
-Rifleman's Creed
Old 10-05-2011, 07:35 PM   #6 (permalink)
saswat23's Avatar
No, CX-430 is not good choice. Go for CX-400 if its available.
Other choices are:
* TAGAN StoneRock 500W -- 3k
* FSP SAGAII 500W -- 2.1k
If you are really tight on budget, then go with FSP SAGAII 500W. It can handle 6670 easily as it has the same power consumption as that of 5670. And when a SAGAII 400W can handle 5670 with ease then why cant SAGAII 500W handle it.
IMO go for SAGAII 500W at 2.1k.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 10-05-2011, 08:33 PM   #7 (permalink)
Adam young
sukesh1090's Avatar
k thank you.btw is there any faults in that corsair 430 one?
-Rifleman's Creed
Old 12-05-2011, 03:17 AM   #8 (permalink)
6670 has power requirement same as 5670 which i am using on a 400W. so FSP Saga II 500W will support it & at 2.1k its a bargain.
- by c4u
