Old 05-05-2011, 02:20 PM   #1 (permalink)
A PC GAMER
Gaurav265's Avatar
Red face problem with mouse
I have a compaq mouse there is problem with it,when i connect it to pc there is a error sound come from cpu not from speakers sound like tittittittttt.and all lights of keyboard blinking and mouse not work and when i connect other mouse work smoothly.mouse is not work also on other pcs.i dont know what the problem if anyone help then pls.
Gaurav265 is offline   Reply With Quote
Old 05-05-2011, 02:52 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: problem with mouse
If other PC's also behave unexpectedly with that mouse, then the mouse itself has problem I guess.
Replace it if it's still under warranty otherwise it's time to get a new one I guess.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now   Reply With Quote
Old 05-05-2011, 02:56 PM   #3 (permalink)
check out the pins of the socket of the mouse. If it ok then try with a new mouse.
GPS: The best way to navigate safely and securely.:smile:
rajeevk is offline   Reply With Quote
Old 05-05-2011, 03:47 PM   #4 (permalink)
Try using a different OS and see if it helps
thetechfreak is online now   Reply With Quote
Old 05-05-2011, 09:17 PM   #5 (permalink)
Living to Play
gameranand's Avatar
Most probably that mouse is faulty because if if there was problem in your PC then it should have worked fine on other PC but sadly it didn't so its mouse that is faulty.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 06-05-2011, 12:21 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
@Gaurav265:is it usb mouse or PS/2
Old 06-05-2011, 11:57 PM   #7 (permalink)
A PC GAMER
Gaurav265's Avatar
my mouse is ps/2 .i think it is faulty.its time to buy new one....................
Old 07-05-2011, 08:38 AM   #8 (permalink)
Yeah most probably.
You will get cheap usb mouse in local shop from Rs.100.
- by c4u
