Old 03-05-2011, 03:34 PM   #1 (permalink)
Default Please recommend the size of UPS for my new PC build
Here are the specification of the new PC I am planning to build:
Intel Core i7 2600k
Asus p8p67 Motherboard
1TB Seagate 7200rpm HDD
2x4GB G-Skill Ripjaws RAM
NVIDIA GTX 590
Corsair 750HX PSU
Dell U2311H 23" Monitor
Netgear WLAN (Wifi) Card
Please recommend an UPS (only APC, no other brands) of appropriate power capacity for this build. Will a 1000VA APC UPS be enough?
This is the one I am planning to buy but not sure if it will be enough:
APC Back-UPS RS, 1000VA, 230V, INDIA
Considering I live in Kolkata, it will be great if someone could link me to an APC model that's available here and also price if possible. Thanks.
nginx is offline   Reply With Quote
Old 03-05-2011, 03:42 PM   #2 (permalink)
Default Re: Please recommend the size of UPS for my new PC build
Yup, that 1000 va is properly enough. Anything less not reccomended.
thetechfreak is online now   Reply With Quote
Old 03-05-2011, 03:46 PM   #3 (permalink)
I am concerned because the GTX 590 is a real power hungry card. Besides, the power factor of that UPS seems to be really low.
More opinions from other members would be great.
Old 03-05-2011, 03:54 PM   #4 (permalink)
what if 1 wants to use a 580 oc with the setup insead of the 590?what ups is recommended?
coolgame is offline   Reply With Quote
Old 03-05-2011, 10:11 PM   #5 (permalink)
yesterday i bought an APC 1100VA UPS (BR1100CI-IN) - 4.37k. u could get that one - pretty solid.
sam1 is offline   Reply With Quote
Old 04-05-2011, 07:34 AM   #6 (permalink)
sam1, that's the same model most shops in Chadni are selling and also recommending but it doesn't have the auto shutdown feature which is very important to me as I often leave my machine unattended while encoding videos. So, I have chosen to go for the 1000VA BR1000-IN model instead.
More opinions please guys. Still can't decide.
Old 04-05-2011, 02:02 PM   #7 (permalink)
RAMPAGE!!!!
modder's Avatar
@nginx
whats your max. budget for the ups? If you're looking for an ups with better PF, go for APC Smart-UPS.
See:
http://bitfang.com/SubCat/Computer-Hardware_UPS.aspx
http://www.primeabgb.com/index.php?p...mart&Itemid=53
Look for:
APC SUA1500I 1500 VA 980 Watts UPS -> 15k
APC SUA1000I 1000 VA 670 Watts UPS -> 13k
modder is offline   Reply With Quote
Old 04-05-2011, 05:58 PM   #8 (permalink)
My budget is 5k (max 6k). APC's Smart-UPS range in too expensive. 13k for 1000VA? That's ridiculous. I can get 1500VA for 9k easily in Kolkata but I cant afford to spend that kind of money on an UPS
This model would suit me well but I fear its not available here:
Buy APC | APC Home UPS 1000VA Sine wave output | Buy UPS
Old 04-05-2011, 06:14 PM   #9 (permalink)
Why dont you try calling them here-
Tel: +91-22-23896600, 23855500,
6740 2000.
Old 04-05-2011, 07:16 PM   #10 (permalink)
but that price for the UPS u mentioned is without the battery.
Old 04-05-2011, 08:53 PM   #11 (permalink)
Without the battery? Oops, then its no good for me.
To be honest, I can get both the 1000VA and the 1500VA APC models locally in Kolkata. So I have no reason to buy online. But since the 1500VA is almost double the cost of the 1000VA, I am just asking whether 1000VA (600W) will be enough for my PC build?
Old 04-05-2011, 09:19 PM   #12 (permalink)
RAMPAGE!!!!
modder's Avatar
That's an inverter, requires battery worth 8-9k. PC/PSU operation with an inverter depends on switching time.
Since you're going for a high-end config with GTX 590 (which alone costs 33k abroad) and all... thought you might be interested in a pure sine wave UPS.
Pure sine wave UPS provides cleaner power to the PSU during backup. APC Smart-UPSs are pure sine wave UPSs, thats why they cost a hell of a lot more dough than modified sq. wave ones.
Its not that a square wave UPSs won't work... even I'm using APC 1.1KVA BR1100CI-IN (modified sq. wave) with Corsair TX750, absolutely no problems so far neither at switching nor during backup.
Get: BR1000-IN or BR1500-IN
BR1000-IN would suffice for HX750
BR1500-IN best for future upgrades/headroom+less stress on UPS during backup at very high load
The online links were for reference only..
Old 05-05-2011, 08:17 PM   #13 (permalink)
modder, once again a big thank you. You have been really helpful to me.
Yes, I know the Smart-UPS produce pure sine wave but I just don't have that kind of money to spare behind an UPS. Hell, I cant even spare enough money for the BR1500-IN which would have laid to rest all doubts and its all because I am sparing no expense behind building a really powerful rig from the bottom up
So I guess I have to settle for the BR1000-IN for now.
Old 05-05-2011, 08:45 PM   #14 (permalink)
RAMPAGE!!!!
modder's Avatar
No worries BR1000-IN is a tried and tested UPS in its price range & it can definitely handle HX750
Just a thought:
How about AX750 instead of HX750 ?
Old 05-05-2011, 09:36 PM   #15 (permalink)
What are the benefits of AX750 over HX750? I am having a difficult time finding HX750 as it is with only MD Computers selling it and that too at an extremely high price. I doubt they have even heard of AX750.
If you know which shop in Chadni sells the HX750 or AX750 at a cheap price, do let me know.
Old 06-05-2011, 12:38 AM   #16 (permalink)
what price are they quoting for hx750?
Old 06-05-2011, 06:58 AM   #17 (permalink)
They want Rs.9200/- for the HX750 while TX750 is around Rs.5900/-. The price difference is huge!!
Old 06-05-2011, 11:47 AM   #18 (permalink)
RAMPAGE!!!!
modder's Avatar
@nginx
HX750 & AX750 should be in range 8k & 9k respectively. They're asking too much for it. Whom did you talk to at MD? Talk to Pradeep da@MD directly. I think they're giving old quotes. Tell them to confirm the price from Corsair distributors first. If they still ask for the same, give Tirupati ent. a call.
Old 06-05-2011, 12:43 PM   #19 (permalink)
i think tirupati will probably quote even more!
Old 06-05-2011, 01:28 PM   #20 (permalink)
iDota
Sarath's Avatar
whats the use of the software?
I was looking at the 1KVA and 1.1KVA UPS by APC too. Didnt understand what the software does
Sarath is offline   Reply With Quote
Old 06-05-2011, 01:41 PM   #21 (permalink)
A 1000va is borderline, go for 1.5kva
and psu at least 1000w from corsair hx/ax or seasonic x or coolermaster silent pro gold
akshayt is offline   Reply With Quote
Old 06-05-2011, 08:47 PM   #22 (permalink)
That software enables you to shutdown PC automatically when battery gets low. Its a great feature to have if you like me, often leave your PC unattended at home.
- by c4u
