Old 02-05-2011, 11:34 PM   #1 (permalink)
Default what is this and where to connect it on motherboard ?
Check the pic...
whats this ? it came with my cooler master elite 430. Where do i connect it ?
Core-i5 2400 | Intel DH67BL | G.Skill 8GB DDR3 1333Mhz | 500GB Segate | CM 430 | Corsair VX550 PSU| BENQ V2410 eco LED Monitor | Genuine windows 7 64-bit Ultimate | Samsung Galaxy S & boring Nokia Lumia 800 :(
noob is online now   Reply With Quote
Old 02-05-2011, 11:42 PM   #2 (permalink)
The Assassin
Cybertonic's Avatar
Default Re: what is this and where to connect it on motherboard ?
there would be a set of pins where you attach multiple cables (4-6 differently colour coded). Check you motherboard manual to find the port.
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 03-05-2011, 12:04 AM   #3 (permalink)
Super Moderator
asingh's Avatar
That is from the chassis. What you hear the BEEP BEEP. Your manual will have a place for that.
asingh is online now   Reply With Quote
Old 03-05-2011, 12:05 AM   #4 (permalink)
no such thing dude
can u check this and tell me exactly which spot is that
Intel® Desktop Board DH67BL - Technical Documents
also check this is what i got in case of header pins.
Old 03-05-2011, 12:21 AM   #5 (permalink)
SO this is the layout
now plz help
Intel® Desktop Board DH67BL — Configuration label for DH67BL
Old 03-05-2011, 12:38 AM   #6 (permalink)
Super Moderator
asingh's Avatar
Damn weird. Cannot find that header on your board.
Old 03-05-2011, 01:22 AM   #7 (permalink)
RAMPAGE!!!!
modder's Avatar
I think you board has an inbuilt piezoelectric speaker (hence no headers provided), so the one that came with your chassis won't be of any use.
See:
Intel® Desktop Board DH67BL — Board component diagram - DH67BL
Look for: V
modder is offline   Reply With Quote
Old 03-05-2011, 08:13 AM   #8 (permalink)
saswat23's Avatar
I also have that type of cable for my Zebronics Aviator Case. Its actually attached in the bunch where all the LEDs cables for Speaker, Restart, SwitchOn, etc.. are connected.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 03-05-2011, 01:04 PM   #9 (permalink)
You don't have to worry about this now. Your motherboard seems to have a built-in speaker near the CMOS battery.
And please, read the section descriptions. You are NOT posting in the correct section. I've moved your thread.
Originally Posted by Index page
PC Components / Configurations
Questions about configurations go here. Strictly Buying Advice - No troubleshooting here.
- by c4u
