Re: NZXT in Bangalore?
Originally Posted by Sarath
I have read a lot about S.P road but have never been there since i dont know where it is must be 35+km away from my place.
Are the prices really low out there compared to others (Computer Warehouse for example)?
Can you suggest some reliable shops. I've read Golcha is good. Any other options?
Where do u stay in Bengaluru..?, its near Town Hall/ K.R Market/Corporation.
well the prices are best u can get there. if u r buying a PC then u can save 1000+ ,but be careful and check the products they give.
u can try these shops.
Ashirwad Computers, Bangalore computers, Jainex computers. Although Golcha is good but i think they are little over priced..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
