Old 30-04-2011, 02:27 PM   #1 (permalink)
Default strange plug of corsair vx550
today m assembling my pc n got corsair vx550 from primeABGB
this has strange psu cord which won't fit in Indian sockets
what to do now?
Core-i5 2400 | Intel DH67BL | G.Skill 8GB DDR3 1333Mhz | 500GB Segate | CM 430 | Corsair VX550 PSU| BENQ V2410 eco LED Monitor | Genuine windows 7 64-bit Ultimate | Samsung Galaxy S & boring Nokia Lumia 800 :(
noob is online now   Reply With Quote
Old 30-04-2011, 02:36 PM   #2 (permalink)
Default Re: strange plug of corsair vx550
Normal Indian sockets take rounded plugs...plz help me guyss
Old 30-04-2011, 02:45 PM   #3 (permalink)
AJJU
azzu's Avatar
This shud help
WA-10 Travel Plug Adapter for India, Nepal, etc. (Type D Small 5 amp BS 546) [WA-10] : Adaptelec.com, International Electrical Specialists
I love and Live to Design
azzu is offline   Reply With Quote
Old 30-04-2011, 02:46 PM   #4 (permalink)
pulkitpopli2004's Avatar
yeah this plug comes with Corsair vx550v..
You can purchase any of the two shown below.. i am using extension board.
I'd explain it to you, but your brain would explode... Trust me :hot:
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB Caviar Black
pulkitpopli2004 is online now   Reply With Quote
Old 30-04-2011, 02:50 PM   #5 (permalink)
but last time when i got router , it also had same plug BUT WITH additional connector which i mounted on it. and this PSU box has no such thing....
hey in that case i too have extension board like this one
will this help ?
Belkin Surge Protector Superior Series 6 Way | Belkin Surge Protector
Old 30-04-2011, 02:53 PM   #6 (permalink)
I am the night! I am....
vickybat's Avatar
@ talktoanil
You can use a standard indian cord instead or buy an indian converter pin and use the cord that came with your psu.
The above belkin board will work fine with your current psu cord.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline   Reply With Quote
Old 30-04-2011, 02:56 PM   #7 (permalink)
Originally Posted by vickybat View Post
@ talktoanil
ohh man...yeah...just tried that and it fits gr8
thanks guys..assembler is about to come. finally got the monitor too.
but as may people recommend this PSU here ,you should also alert the OP about such things.
tonight will post the pics
Old 30-04-2011, 03:10 PM   #8 (permalink)
You can buy a 110v to 220v connector or whatever it is called, not a problem at all
akshayt is offline   Reply With Quote
Old 30-04-2011, 04:08 PM   #9 (permalink)
Crowman
Krow's Avatar
Well, usually spikeguards take both American and Indian type plugs.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline   Reply With Quote
Old 30-04-2011, 04:20 PM   #10 (permalink)
so if i use that with Belkin spike guard linked in my above post , will it be an issue ?
ok..now 1 more question....
the PSU fan should be facing downwards on filter grid of my CM 430 or upwards which has lower mount PSU system?
Old 30-04-2011, 05:14 PM   #11 (permalink)
saswat23's Avatar
CM 430 is a bottom mounted PSU Case, so ur PSU's fan must face upwards when u install it at the bottom of ur case.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 30-04-2011, 05:31 PM   #12 (permalink)
RAMPAGE!!!!
modder's Avatar
Nope. But would recommend a universal converter/adapter. I am using one too.
The fan will face downwards. See:
http://www.thinkdigit.com/forum/hard...on-thread.html
modder is offline   Reply With Quote
Old 30-04-2011, 06:56 PM   #13 (permalink)
Super Moderator
asingh's Avatar
Anil, will tell you the simplest thing to do. I did this and it worked quite fine.
Take that cord, and show it at ANY electrical shop. He will pull out a adapter. Note this is not converter so voltages remain same.
Simple. No use for belkin strips and all.
asingh is online now   Reply With Quote
Old 30-04-2011, 07:23 PM   #14 (permalink)
The Sorcerer's Avatar
@ talktoanil
You can use a standard indian cord instead or buy an indian converter pin and use the cord that came with your psu..
^^ Avoid this. Many "rabbits" pull out unknown adapters from unknown hats
^^Much better doing this.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 30-04-2011, 08:28 PM   #15 (permalink)
Treatment in progress...
mukherjee's Avatar
If I might put this simply, for 30 bucks,get an MX converter....that did the job for me.
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline   Reply With Quote
Old 30-04-2011, 08:48 PM   #16 (permalink)
The Assassin
Cybertonic's Avatar
Many PSUs have this plug these days. Even my CM GX550 came with it. The simplest solution is to use an adapter like in the first pic by pulkit.
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 03-05-2011, 01:09 PM   #17 (permalink)
Wrong section. Thread moved to Hardware Q&A. This is a buying advice section as mentioned in the description. So queries like yours will go to Hardware Q&A. (you've already bought what you wanted.)
Old 03-05-2011, 04:09 PM   #18 (permalink)
Bond, Desi Bond!
desiibond's Avatar
better not get those el-cheapo adapters. Get the Belkin connector or something similar. Brands like Cona and Anchor too sell good quality multipoint connectors. Do take the cable to the shop and test before buying (make sure it fits)
desiibond is offline   Reply With Quote
- by c4u
