Old 29-04-2011, 02:34 AM   #1 (permalink)
happy17292's Avatar
Default no network adaptor... no LAN
one of my friend had pentium D, 512MB RAM, AsRock 775i65GV motherboard. i bought it from him as i wanted to set up a LAN based gaming to play with my friends.
problem is i bought only motherbaord and CPU.
i installed my RAM and 40GB IDE HDD and CD ROM then installed XP SP3
i downloaded drivers from official site of ASRock and installed them
when i clicked network connections from control panel, it shows blank window, there is no LAN connection shown there. if i try to set up a home or small office network, it shows cannot complete network setup wizard. cannot find your network hardware.
if checked in device manager, there is no network adaptor there
what should i do? this board has LAN port and i have installed LAN drivers too
please help ASAP
AMD Phenom II X4 B25, Gigabyte GA78LMT-S2P rev.3.1, 4GB corsair value select DDR3 1333MHz, Sparkle GT240 1GB DDR3, 1TB WD caviar blue
NO ODD :|
LG optimus one P500 on stock gingerbread
Xbox 360S 4GB [modded]
Playstation 3 160GB on 3.55 cfw
:grin:
happy17292 is offline   Reply With Quote
Old 29-04-2011, 09:04 AM   #2 (permalink)
Default Re: no network adaptor... no LAN
Try these websites and undestand you might be missing something-
How to Setup Internal LAN | eHow.com
How to set up a lan party?
How to setup a lan gaming network
Also, double check connecting wires, modems properly. Try using different lan cable
thetechfreak is online now   Reply With Quote
Old 29-04-2011, 11:14 AM   #3 (permalink)
Super Moderator
asingh's Avatar
Have you installed all the chipset drivers for that board.
asingh is online now   Reply With Quote
Old 01-05-2011, 07:52 PM   #4 (permalink)
happy17292's Avatar
can any1 tell me which driver i need? plz send me link.
i downloaded it from asrock site.
this is the mobo : AsRock 775i65GV
plz check specs and tell me correct drivers
NO ODD :|
:grin:
Old 02-05-2011, 02:53 AM   #5 (permalink)
saswat23's Avatar
download all the drivers available for ur mobo.
Probably:
* graphics - video drivers
* Audio - sound drivers
* LAN - for integrated lan and lan cards
if any other drivers are available other than these, then download and install them too.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 02-05-2011, 03:29 AM   #6 (permalink)
happy17292's Avatar
Probably:
i know. i just want someone to google that motherboard and read its specs then tell me LAN driver to install. and send me link as i dont know if i have installed the correct one or not
NO ODD :|
:grin:
- by c4u
