Old 28-04-2011, 11:28 AM   #1 (permalink)
Unhappy Help: No display on Monitor after turning ON.
Hai i am new to this FORUM but am a reglr reader of DIGIT.
When i turn ON my pc, the whole thing in the cabinet starts working BUT there is NO DISPLAY on monitor.
I came 2 know that the solution was 2 turn pc off, discharge all capacitors and turn it back on.Sometimes it works sometimes not.
But the problem still persists
Is it due to BAD ram or a failing PSU???
Specs:
Core2Duo E4500 2.2ghz
2 GB ddr2 ram Kingston
Intel D945GCNL
Asus 5750 Formula 1 GB
FRONTECH 450W PSU
Jishnu is offline   Reply With Quote
Old 28-04-2011, 11:42 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Help: No display on Monitor after turning ON.
yes u r right its RAM...
If PSU is faulty then either the fans wont work or frequent restarts
Old 29-04-2011, 11:12 AM   #3 (permalink)
Question Re: Help: No display on Monitor after turning ON.
But now i found out the culprit...
my gfx card's the one.
ma pc wrks smoothly when i pluggd my monitrs's cable 2 Intel intgrtd gfx output.
am vry dispntd i just bought mycard last Sept.
ANY SUGGESTIONS.....
Old 29-04-2011, 11:16 AM   #4 (permalink)
Fullbring
Zangetsu's Avatar
^^if the card is under warranty then send the card to RMA process
Old 29-04-2011, 02:29 PM   #5 (permalink)
atulhost's Avatar
I think this thread to be made sticky with the subject 'Display Problems' so rather than opening new thread I would like to carry on this thread. I am from Nasik and I am facing problem with my 'Compaq mv540'(2003) monitor, display is not responding at all. Only the light near on of switch remains red(which used to turn green when display is working). As it is out of warranty now, I can not get any help from authorized Compaq authority. I would like few suggestions from Think-Digit community. May I repair it ever?
Note :- No problem from CPU side as newly replaced ViewSonic working fine.
Host.co.in - Web Hosting India
atulhost is offline   Reply With Quote
- by c4u
