Old 28-04-2011, 05:41 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default APC UPS problem!
Hey Guys,
I have the BE650Y-IN model, using it for almost 20 months. It was working fine till yesterday night when I went to sleep [left the pc on downloading stuff].. but this morning when I checked, everything was off.. so I started the UPS & the LED started alternating amber and green giving out 2 short beeps every couple seconds. PC started fine & it seems to be working fine but the beeps are annoying. Can anyone tell me what's wrong? Is the battery nearing end of life? Do I have to recharge it for a certain amount of time before using it again?
Thanks,
Vish.
Anybody????
Intel® Core™ i7-2600 | ASUS P8H67-M EVO | NZXT Tempest EVO | Corsair VX450 & XMS3 16GB 1600MHz | Dell U2311H | MSI N460GTX Cyclone 1GD5/OC | CM Hyper 212 Plus | APC 650VA | Creative Inspire 4.1 4400 |
Vishw is offline   Reply With Quote
Old 28-04-2011, 06:02 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: APC UPS problem!
I think it was not getting enough voltage, hence that noise and blinking light.
Plz let us know if this continues or re-occurs at specific times?
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now   Reply With Quote
Old 28-04-2011, 06:08 PM   #3 (permalink)
Well, abt 10 min ago.. somehow that behavior stopped & it's green only now & seems to be working properly! Hope it continues that way!
Will let you know if it starts misbehaving again!
Old 28-04-2011, 06:14 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
what is there between your UPS and plug point? Do you use any spike buster?
Old 28-04-2011, 06:17 PM   #5 (permalink)
Nothing.. its directly connected to wall outlet.
It worked flawlessly for 20 months.. this is the first time it's misbehaving..
Old 28-04-2011, 06:26 PM   #6 (permalink)
Democracy is a myth
rhitwick's Avatar
ok. Do one thing. Get a spike buster (don't buy, if possible borrow it from ur friend) and keep it with you.
(if the electricity is not off and)
The moment your UPS starts noise unplug it, put the spike buster in between plug and UPS. Such that now the power first comes to spike buster and UPS takes power from spike buster.
Try it and report.
(Why this weird solution: I kinda faced this similar situation, resolved it this way. Need to if you have the same issue or ur battery is dead)
Old 28-04-2011, 10:07 PM   #7 (permalink)
iDota
Sarath's Avatar
Even i'm getting an APC UPS. Hope i dont face any such problems.
Your problem reminded me of the Home UPS we had with the annoying beeps so much so that we stopped using it.
Scheider electric is good otherwise.
Sarath is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/139865-apc-ups-problem.html
Thread circuit diagram for APC Back-UPS Pro 500VA (BP500I) | Digit Forum | BoardReader This thread Refback 31-05-2011 04:34 PM
- by c4u
