Re: How to install front fan in CM Elite 310
Cooler Master Elite 310 - Bjorn3D.com
r u sure u doing correctly , i didnt have problem when i installed CM 120mm LED fan to my CM 310 cabnet , only problem i faced was screw supplied it Fan was 2 big once , so i just inserted the CM 120mm fan to provided slot , even without screw it was holding tight (no vibration /shake when running)
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
Reason: typo
