23-04-2011, 05:59 PM
pendrive space lost!!!!!!!!
hi
i formatted a pendrive from windows7 of 16gb while formatting i forgot to check the settings and after format it gave me FAT partition and only 68mb of free space can anybody help me out of it how can i bring the 16gb space back?
pls reply
23-04-2011, 06:16 PM
Re: pendrive space lost!!!!!!!!
agian format it changing to NTFS format
23-04-2011, 06:52 PM
Please elaborate it. You arent very clear.
23-04-2011, 09:24 PM
AJJU
This should help i guess,
connect it to the system , Format the drive using NTFS file system
I love and Live to Design
23-04-2011, 11:00 PM
Electronic.
Originally Posted by shrirangbhavsar
hi
pls reply
Which is the brand of your pendrive?Is this the first time you are formatting it?Some non-standard pendrives fake their capacity at first and when formatted they reveal their actual capacity.
I don't always make sense,but when I do,I don't.
24-04-2011, 06:54 PM
i formatted it from xp first then it was ok but after formatting from windows 7 it is showing only 67mb FAT filesystem, and now its also not allowing me to change the filesystem now can u give me any software to recover my 16 gb
24-04-2011, 06:58 PM
Is your Pendrive used for Ready Boost in Windows 7? I think yes.....
25-04-2011, 10:26 AM
no its not used for ready boost is there any software to recover my space lost?
25-04-2011, 10:32 AM
Mmmph!!!
there is no "software" for this.
1.go to my computer
2.right click pen drive
3.choose format
4.from dropdown menu, select ntfs as filesystem
5. leave the rest of the settings as default.
6. format
if this does not work do it 2 more times, and refresh. other than that, i can suggest :
1. format drive in someone else's computer
2. tell us what company of is the pendrive
3. format in linux
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
25-04-2011, 12:09 PM
You haven't replied to this? Is it a cheap Chinese one?
26-04-2011, 08:53 AM
no its not chinese but its cheap its the spy pen camera with 16gb space
26-04-2011, 09:33 AM
Uhu, Not Gonna Happen!
then it has to be chinese, don't you think so
My personal blog - http://gagan.scholarguru.com
26-04-2011, 10:24 AM
Mmmph!!!
i got a drive of 8gb(printed on the box) for rs 150, but it didnt work. when i broke open the case, i saw that it didnt have the main controller chip on it. i felt like smacking my head against a wall. from then on, i always try to break open the pen drive in front of the shopkeeper, if im buying from a shady source.
Steam : doomgiver
26-04-2011, 11:20 AM
LOL thats cheapo device, lucky that even 68mb is working. This is fake mate, 16 gb is just for attracting customers.
Chill out leave with it
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
26-04-2011, 11:49 AM
Mmmph!!!
use it for booting puppy linux
Steam : doomgiver
26-04-2011, 11:52 AM
Fullbring
did u buy it from Naaptol.com???
this pendrive ad is always shown in LCD TV of BEST buses...
price is around 1700/-
26-04-2011, 05:22 PM
Nice idea. Maybe even Damn Small Linux
26-04-2011, 05:28 PM
Mmmph!!!
^ dsl wont recognise my mouse, usb or touchpad
Steam : doomgiver
26-04-2011, 08:09 PM
#19 (permalink)
@shrirangbhavsar
Try this it might works
1. right click on my computer
2.click on "manage"
3.click on "disk management" under "storage"
4. then right click on your pendrive partition (after plugging ur pendrive)
5. Now click on "Delete logical drive"
6. now ur pendrive partition will be deleted.
7. now u will see green color free space, right click on that and choose create new partition.
8 And ur are Done!! I hope this will solve ur problem
If U mess with me, U will be HACKED!!
Get all Hacking Tips & Tricks, on www.gen-xtechcentre.webs.com
