Old 22-04-2011, 10:42 AM   #1 (permalink)
Never give up!!
jerrin_ss5's Avatar
Default Cabinet and CPU cooler recommendation
hey i was planning to buy a new cabinet with a budget of abt. 2.1k and cooler of budget 1.2k
so i narrowed down my search to NZXT Gamma
NZXT :: Unique. Unprecendented. Inspired - Gamma Product Detail
mainly b'coz of its cable mgmt. feature
and CPU cooler to Cooler Master Hyper TX3 CPU Cooler
Hyper TX3 - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply
of this i am pretty sure of buying the cabinet as mine is a crappy one which heats up the components
and need ur help guys regarding buying the cooler as my stock CPU fan makes noise and has rpm abt 5000-6000 RPM
Here are some pics !!
ImageShack® - Online Photo and Video Hosting
so pls help guys !
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 22-04-2011, 02:06 PM   #2 (permalink)
MegaMind's Avatar
Default Re: Cabinet and CPU cooler recommendation
Ur temps seems to b normal...
Try playing games like crysis 2 or any graphics demanding games n post the temps...
Regarding cabby...
If cable management is ur main preference, get Gamma else get CM 430..
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 22-04-2011, 04:32 PM   #3 (permalink)
Confusingly Confused!
scudmissile007's Avatar
jerrin_ss5,IMO if u are worried about the temps,get a better cooler like hyper 212+ & nzxt gamma. hyper212+ CPU cooler will be a better upgrade & it can be used in future if u upgrade the cpu.
C2D e8400,MSI P45 neo,transcend 3x1gb ddr2 667Mhz,Zotac gtx 460 1gb,Corsair vx550,NZXT Gamma,Razer deathadder,viewsonic 19",Samsung galaxy s i9000.
Gunner 4 life."VICTORIA CONCORDIA CRESCIT".
scudmissile007 is offline   Reply With Quote
Old 22-04-2011, 04:40 PM   #4 (permalink)
MegaMind's Avatar
@OP, wat r the temps u are gettin on proccy?
if u are not OCing, Aftermarket cooler is a waste of money...
Old 22-04-2011, 05:20 PM   #5 (permalink)
Never give up!!
jerrin_ss5's Avatar
at load my temperatures of CPU go upto 65-70 and GPU upto 75-80 like when playin intensive games
the problem is that my stock CPU cooler is making noise and is having RPM of 6000 at load is that normal ?
i have not overclocked any settings !!!
@mailme.manju i saw ur pics of NZXT gamma and it was superb re !!!
Old 22-04-2011, 05:47 PM   #6 (permalink)
MegaMind's Avatar
Thats completely normal... Jus forget abt the CPU cooler..
Thanks a lot...
Old 22-04-2011, 08:28 PM   #7 (permalink)
Never give up!!
jerrin_ss5's Avatar
Thanx re for the help @mailme.manju
so going ahead and buying NZXT Gamma !!
Old 22-04-2011, 09:28 PM   #8 (permalink)
MegaMind's Avatar
Cool, dont forget to post the pics...
Old 22-04-2011, 09:35 PM   #9 (permalink)
Never give up!!
jerrin_ss5's Avatar
hey ya i will sure
but where to post the pics here or to ur thread !!!
Old 22-04-2011, 09:38 PM   #10 (permalink)
MegaMind's Avatar
NZXT Gamma is a great cabby!!!
Thread for Gamma users
- by c4u
