Old 20-04-2011, 10:10 PM   #1 (permalink)
Default Gigabyte GA-890GPA-UD3H with a Gigabyte Geforce 8600GT?
Hello,
I bought a motherboard Gigabyte GA-890GPA-UD3H - Socket AM3 - Chipset 890GX - ATX and will use it to construct a new computer.
Right now i already ordered a AMD Phenome II X6 1090 - Socket AM3 (processor), and now my problem is with the graphic card.
I really don't want spend much more money, and like i have one Gigabyte Geforce 8600GT, I would like to know, in case someone can help, if I can sue this graphic card in the motherboard that I made reference.
Thanks
kadonga is offline   Reply With Quote
Old 21-04-2011, 01:45 AM   #2 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Default Re: Gigabyte GA-890GPA-UD3H with a Gigabyte Geforce 8600GT?
Yes you can *use the 8600gt in the quoted motherboard.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is online now   Reply With Quote
Old 21-04-2011, 09:07 AM   #3 (permalink)
what PSU do you have? If you have a good,branded one get a Sapphire Raedeon 5770hd @4.5 k
The proccy wont even be utilised to full potential with the 8600gt.
thetechfreak is online now   Reply With Quote
Old 21-04-2011, 10:05 AM   #4 (permalink)
Super Moderator
asingh's Avatar
What you mean..processor not used to full potential.
asingh is online now   Reply With Quote
Old 21-04-2011, 10:24 AM   #5 (permalink)
I mean wont the proccy be bottlenecked by the 8600? He can get lot better performance in games with better gpu.
Old 21-04-2011, 10:39 AM   #6 (permalink)
Super Moderator
asingh's Avatar
It is the other way round. Processor supplies to the GPU. Plus the goal is always to have the CPU idling (or low) and the GPU doing most of the work.
Old 21-04-2011, 11:32 AM   #7 (permalink)
MegaMind's Avatar
Low-end CPU + high-end GPU = Bottleneck...
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 21-04-2011, 12:53 PM   #8 (permalink)
I know but wont it happen other way round?
Old 21-04-2011, 01:30 PM   #9 (permalink)
Super Moderator
asingh's Avatar
No, then you have a slow GPU.
Old 21-04-2011, 03:56 PM   #10 (permalink)
Thanks to all, for the quick reply
Seems this part is solved...
- by c4u
