Old 17-04-2011, 07:00 PM   #1 (permalink)
GAMING IS NOT A CRIME
jkultimate's Avatar
Default PC turning off suddenly when doing this
Ok, my Pc is turning off when I convert a video of sizes some gigs. Or when I cut some videos. Software used for converting is Total Video Converter full version.
The CPU usage becomes 100% in both cores and about in some seconds pc will turn off.
I scanned for any viruses, but not a single virus was detected by Avira Anti-virus personal, licensed version.
Pc config:
AMD Athlon 64 X2 4000+ @ 2.1Ghz
Msi-K9mmv
2GB Zion ddr2 800Mhz
Zebronics 300 watts
Intex 15" widescreen
Logitech m+kb
No video card!!!!
Please tell me the problem.
IS THE PROBLEM WITH THE POWER SUPPLY?
jkultimate is offline   Reply With Quote
Old 17-04-2011, 07:19 PM   #2 (permalink)
MegaMind's Avatar
Default Re: PC turning off suddenly when doing this
Two possibilities....
1.CPU overheatiing,
2.PSU insufficient...
Check temps while doing video conversion...
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 17-04-2011, 08:00 PM   #3 (permalink)
Mmmph!!!
doomgiver's Avatar
i think the culprit may be psu. 300W zebronics.
does the computer hang, or just turn off? does it give an error? does it happen everytime?
does it happen in regular usage?
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
Old 18-04-2011, 10:11 AM   #4 (permalink)
jkultimate's Avatar
Talking Re: PC turning off suddenly when doing this
It doesn't hang and does not shows a error after this turning off.
Yeas it happens every time I convert a video, and when I make a video with pictures using Picasa 3
Old 18-04-2011, 11:42 AM   #5 (permalink)
Fullbring
Zangetsu's Avatar
@jkultimate: check the CPU temp
cud be problem of
1) RAM
2) PSU
3) CPU
Old 18-04-2011, 02:48 PM   #6 (permalink)
In search of Peace...
papa's Avatar
IMHO.......
1.might be cpu temp.At 100% load the cpu heats up really fast.Check cpu temp.
2.might be due to faulty ram.If you have spare ram,can try with that.
Asus Sabertooth X58;Intel i7 960;Noctua NH D-14 CPU Cooler;G Skill 3X2 GB DDR3 Ram;MSI HD6970 2Gb;Corsair TX 750;Cooler Master HafX Chassis ;Razer Cyclosa Bundle; Windows 7 Ultimate 64bit.
papa is offline   Reply With Quote
Old 18-04-2011, 07:45 PM   #7 (permalink)
try it with Format Factory. it the PC still turns off all of a sudden, time for some PSU upgrade.
Old 18-04-2011, 11:28 PM   #8 (permalink)
newway01's Avatar
How many active HDD's and optical drives you have? Try detaching all optical drives and extra hard disks to check if the PSU is a culprit. Run system with only your OS HDD and try converting the video. Since you don't have any graphics card, and with a less power hungry processor, your PSU may be sufficient to run with barebone setup.
Download and install speedfan app and keep an eye on processor temp. Is your system well ventilated?
Also whats your Windows swap file size? Does you Windows drive got enough space to hold any temporary files generated during conversion?
newway01 is offline   Reply With Quote
Old 18-04-2011, 11:44 PM   #9 (permalink)
Crowman
Krow's Avatar
Try checking temperatures with CPUID Hardware Monitor.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline   Reply With Quote
Old 19-04-2011, 09:08 AM   #10 (permalink)
Ram problem according to me.
Refit them. Even I had this 2 years back.
Otherwise Psu or overheating is the culprit.
I bet you turn off the pc by directly switching off the power
thetechfreak is online now   Reply With Quote
Old 19-04-2011, 11:47 AM   #11 (permalink)
jkultimate's Avatar
I have only one HDD internal i.e WD 160GB and Lg dvd writer.
I'll download speed fan and try convertting.
Thanks
Old 19-04-2011, 01:19 PM   #12 (permalink)
Wise Old Ghoul
Piyush's Avatar
only 2 possibilities
-->PSU not sufficient
-->CPU too hot to continue
this is the same problem that another member on tdf had a couple of moths ago(forgot the name)
he had Iball 450W PSU and was doing video editing
and when he changed his PSU, the problem resolved
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
- by c4u
