Hi
today i was browisuing through my BIOS and it showed the display adapter set as PCI E.
In the list there was INT VGA and PCI also. would there be any difference if i changed it to the others.
I dont have a GPU.
My mobo is ASUS P5sd2-vm
Keep the faith, not here to win trophies, not here to win the league, only here to show people how we play.... ARSENAL!!!!!!!!!!!!!!!
If you choose PCI E then the system will select the PCI E graphics card if available,else it will use the onboard/integrated graphics chipset.
INT VGA=Integrated graphics chipset(Video/Visual Graphics Adapter to be precise).
PCI - Selects the PCI graphics card if you have any.
I don't always make sense,but when I do,I don't.
