Old 13-04-2011, 02:28 PM   #1 (permalink)
Neophyte
Default 2GB & 4GB Ram will support or not
I am using DDR 3 2GB ram of Kingston and i an planning to upgrade my ram to 6GB by buying 4GB ram will the two (2GB and 4GB) going to support or not..
Plz HELP....
manab_bikash is offline   Reply With Quote
Old 13-04-2011, 03:22 PM   #2 (permalink)
Wise Old Ghoul
Piyush's Avatar
Default Re: 2GB & 4GB Ram will support or not
it will support
but do post the details of your motherboard
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 13-04-2011, 04:22 PM   #3 (permalink)
are you planning to get 4GB x 1 or 2GB x 3 ??
If you have 4 DIMM slots , go for 2GB x 3 way
noob is online now   Reply With Quote
Old 13-04-2011, 06:09 PM   #4 (permalink)
Living to Play
gameranand's Avatar
@ OP
Yes it will support but you should rather consider to follow Anil's Advice. It that case it will perform better. Get 2GB*3.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 13-04-2011, 09:03 PM   #5 (permalink)
installing a new stick or two with old one gives BSOD sometimes & other errors.
@manab_bikash, take the CPU to shop & ask them to install 4Gb ram as a stick or 2X2Gb kit (if you have 4 DIMM slots) & check if PC boots up nicely. thats the best way i know.
- by c4u
