Old 11-04-2011, 11:06 PM   #1 (permalink)
Default Need a Wifi USB dongle (Adapter)
I have 1 mbps mtnl broadband connection, on a Beetel 450 TC1 router. I want to connect net with second desktop computer 10-12m away. Which is a stable USB dongle/adapter for my configuration? Budget is around 9-1.2k
Saurav2007 is offline   Reply With Quote
Old 12-04-2011, 08:46 AM   #2 (permalink)
Computer Addict
meetdilip's Avatar
Default Re: Need a Wifi USB dongle (Adapter)
A friend of mine bought one from Netgear (through ebay) for Rs. 900. He seems quite happy with it.
meetdilip is online now   Reply With Quote
Old 12-04-2011, 11:47 AM   #3 (permalink)
Fullbring
Zangetsu's Avatar
Models from Belkin are also good...
Q:Can we use WIFI USB dongles in a desktop PC to create WIFI access points??
Old 12-04-2011, 12:17 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Ya..using Connectify.
asingh is online now   Reply With Quote
Old 12-04-2011, 02:30 PM   #5 (permalink)
any specific models. How is the Asus N10?
Old 12-04-2011, 03:56 PM   #6 (permalink)
saswat23's Avatar
Whats the price of Asus N10..???
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 14-04-2011, 01:02 PM   #7 (permalink)
Made a disastrous bad buy
Bought the Asus Wl-167G V3 for 750 bucks from c2c. The damn thing does not work on my desktop just 6m away across a wall. It works fine when i use within 1-2m of the router though.
I wish i had stuck with the Asus N10 instead, which has a better MIDA antenna. Its also available for just 850 at ebay
Now need to buy a PCI Wireless card. Still hunting for a model which just WORKS
Edit:
It works, albeit the router has to be placed atop the table or fixed to the wall. The N10 is definitely the better and safer purchase
- by c4u
