Old 11-04-2011, 12:22 PM   #1 (permalink)
Post DDR 3 RAM query
My current PC configuration are Intel core i3 530+Intel DH55TC MB+ 1 Tb seagate HDD + XFX RADEON HD5450 1GB DDR3 + 2Gb DDR3 1333 Zion RAM. i want to replace my RAM with 4 GB corsiar DDR3 1333 XMS which comes with heat-sink. will it match with my configuration and are this corsiar heat sink RAM be better then Zion normal RAM?
TirthRaj89 is offline   Reply With Quote
Old 11-04-2011, 12:53 PM   #2 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Default Re: what mobile to buy under Rs 10,000
Zion RAM is a piece of chinese crap... Corsair is awesome... the best. But I don't know if it would be compatible with your current motherboard...
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is online now   Reply With Quote
Old 11-04-2011, 01:20 PM   #3 (permalink)
Living to Play
gameranand's Avatar
Default Re: DDR 3 RAM query
They will be compatible. Don't worry about that.
Yes Corsair RAM are better than ZION.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 14-04-2011, 09:21 PM   #4 (permalink)
127.0.0.1
mitraark's Avatar
Chinese Crap would be a little exaggeration.
But yes COrsair definately recommended. Also , don;t replace ,just add.
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
- by c4u
