Old 11-04-2011, 10:32 AM   #1 (permalink)
gdatuk's Avatar
Default SDHC card not recognized in Windows pc
I have a 32GB sandisk SDHC card with my Nikon D3100. I have been using it for over 5 months now. I pull out the SD card from camera and plug in a generic card reader to connect to PC. everything was fine until today morning.
The PC wont't recognize the SD card anymore. It asks me to format it. I tried in other laptops and PCs but still the same issue. Anybody faced a similar problem and how can it be solved?
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline   Reply With Quote
Old 11-04-2011, 11:51 AM   #2 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Default Re: SDHC card not recognized in Windows pc
What does camera says when you insert memory card?
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is online now   Reply With Quote
Old 11-04-2011, 12:31 PM   #3 (permalink)
gdatuk's Avatar
The camera reads it perfectly. So i tried with a new card reader and it worked perfectly.
Problem Solved
Twitter @cgiridhar
- by c4u
