LinkBack (4) Thread Tools Display Modes
Old 11-04-2011, 10:09 AM   #1 (permalink)
official's Avatar
Location: A small town near Siliguri, West Bengal in Darjeeling district
Unhappy RAM problems in win 7 x64..help needed asap
Guys...let me post the pics first..k here u go.
as u guys can see the amount of ram installed is 4gigs whereas usable is only 2..my OS is x64 win 7 with latest updates..now how come i cant use entire 4 gigs of ram ???? plz suggest..my i5 pc has turned into a celeron one ....
Core i5 750, MSI p55m gd45, 2x2gb corsair, Dell s2409w 24'', ATI HD5770 1GB DDR5, CM690, windows 7 ultimate 64x, PS3 80GB Console.
PSN Id- subhasis13
official is offline   Reply With Quote
Old 11-04-2011, 10:14 AM   #2 (permalink)
Default Re: RAM problems in win 7 x64..help needed asap
Please put a larger photo. I think you copy pasted thumbnail version.
Disable Page file.YOu have probably upgraded from 2 gigs of RAM and hence Page file isnt showing more .You will get 4 gb full. Otherwise increase page file to 4 gb if you dont want to disable.
I think your onboard GPU is using RAM. Try reducing that much from BIOS
thetechfreak is online now   Reply With Quote
Old 11-04-2011, 10:16 AM   #3 (permalink)
Super Moderator
asingh's Avatar
How will disable / enable of the page file affect this..? Anyways page file is 1.5 x total hardware RAM.
Try a reseat, of the DIMMs. Also what is CPU-Z reporting.
asingh is online now   Reply With Quote
Old 11-04-2011, 10:38 AM   #4 (permalink)
official's Avatar
i am using 4 gigs of ram from beginnin...and it never showed 1.99 gigs usable before ...it only started 3 days ago..
@techfreak my mobo has no onboard vga..
PSN Id- subhasis13
Old 11-04-2011, 10:43 AM   #5 (permalink)
remove both ram modules and try them one at a time, one of them might have become defective!
akshayt is offline   Reply With Quote
Old 11-04-2011, 10:59 AM   #6 (permalink)
official's Avatar
here is closer pics...one more thing whenever i restart my pc takes power and looses it again n again ut starts and switches off continuously for 4-5 times and then it starts??
this is what task manager says...
???? plz help guys
i'll just remove both modules and check allright...
PSN Id- subhasis13
Old 11-04-2011, 11:36 AM   #7 (permalink)
Super Moderator
asingh's Avatar
Either a module is dead/dying or not seated fine.
Old 12-04-2011, 07:16 AM   4 links from elsewhere to this Post. Click to view. #8 (permalink)
Living to Play
gameranand's Avatar
Your Mobo is defective AFAIK. Because as it starts in 4 to 5 times then I think it tries to recognize your RAM but unable to do so. Try these on someone else's PC and see what happens.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 12-04-2011, 07:25 AM   #9 (permalink)
I think it may be a mobo problem or Its a module problem.
Try using your pc with individual modules.
Whever the pc refuses to boot that stick is defective.
Old 12-04-2011, 08:46 AM   #10 (permalink)
Electronic.
Neuron's Avatar
Go to the screen resolution adjustment screen.Then click 'advanced settings'.In the appeared box,check the amount of shared memory.
Sharing of 3GB of RAM is very unlikely but still just check.
I don't always make sense,but when I do,I don't.
Neuron is online now   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/139202-ram-problems-win-7-x64-help-needed-asap.html
What Plugin/Hack is this? - Mouseover for abbrevation full form - vBulletin.org Forum Post #0 Refback 04-04-2012 12:13 AM
What Plugin/Hack is this? - Mouseover for abbrevation full form - vBulletin.org Forum Post #0 Refback 11-10-2011 01:59 PM
Suggestions by Ishu - Page 5 - Gadget Guru Forums Post #0 Refback 25-09-2011 11:10 PM
What Plugin/Hack is this? - Mouseover for abbrevation full form - vBulletin.org Forum Post #0 Refback 25-09-2011 02:08 PM
- by c4u
