Old 10-04-2011, 09:23 PM   #1 (permalink)
Default MOBO n RAM combination
Hi Guys,
How do you determine if a particular RAM is compatible with motherboard.
E.g I am buying Intel H61WW motherboard and i wish to buy single 4GB stick for same.
Which parameters are to be considered here ?
noob is online now   Reply With Quote
Old 10-04-2011, 09:44 PM   #2 (permalink)
Living to Play
gameranand's Avatar
Default Re: MOBO n RAM combination
Yes you can do that and infact for future its best. As it has two DIMM slots and if you get one 4GB DDR3 1066/1333 MHz then you can further upgrade your PC in future with more RAM and get 8 GB.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 10-04-2011, 09:45 PM   #3 (permalink)
Super Moderator
asingh's Avatar
The motherboard page mentions it usually.
You would need DDR3.
asingh is online now   Reply With Quote
Old 10-04-2011, 09:46 PM   #4 (permalink)
How do i know that the 4GB DDR 1333 mhz ram i am picking is compatible with Intel H61WW mobo or any other for that matter.
will this RAM work ?
Old 10-04-2011, 09:52 PM   #5 (permalink)
Living to Play
gameranand's Avatar
^^ Any 4GB DDR3 1333 MHZ will be compatible. Compatibility is not an specific company issue. No matter which company's RAM you pick it'll be compatible.
The RAM you mentioned is compatible.
Old 10-04-2011, 09:54 PM   #6 (permalink)
Super Moderator
asingh's Avatar
It should be mechanically compatible. Rest works. All DDR3 is slotted (physically) the same. That is all that counts.
Old 18-04-2011, 07:00 PM   #7 (permalink)
In search of Peace...
papa's Avatar
pal....every mobo manufacturer gives a QVL for the ram.It should be in the user guide accompanying the mobo.
Other than that ...you have to Google
Asus Sabertooth X58;Intel i7 960;Noctua NH D-14 CPU Cooler;G Skill 3X2 GB DDR3 Ram;MSI HD6970 2Gb;Corsair TX 750;Cooler Master HafX Chassis ;Razer Cyclosa Bundle; Windows 7 Ultimate 64bit.
papa is offline   Reply With Quote
- by c4u
